GIMP print dialog issues
30 of 33 messages available
GIMP print dialog issues Brian Thomason 16 Aug 01:12
  GIMP print dialog issues Robert L Krawitz 16 Aug 01:22
  GIMP print dialog issues michael chang 16 Aug 01:30
   GIMP print dialog issues Brian Thomason 16 Aug 01:34
    GIMP print dialog issues michael chang 16 Aug 01:38
     GIMP print dialog issues Brian Thomason 16 Aug 01:43
    GIMP print dialog issues michael chang 16 Aug 01:40
     GIMP print dialog issues Brian Thomason 16 Aug 01:52
      GIMP print dialog issues Robert L Krawitz 16 Aug 03:44
     GIMP print dialog issues Akkana Peck 16 Aug 02:24
   GIMP print dialog issues Robert L Krawitz 16 Aug 01:39
    GIMP print dialog issues michael chang 16 Aug 01:41
     GIMP print dialog issues Robert L Krawitz 16 Aug 03:40
43012536.9050107@linspirein... 07 Oct 20:24
  GIMP print dialog issues Robert L Krawitz 16 Aug 01:38
   GIMP print dialog issues Brian Thomason 16 Aug 01:50
    GIMP print dialog issues Robert L Krawitz 16 Aug 03:46
     GIMP print dialog issues Brian Thomason 16 Aug 04:30
      GIMP print dialog issues Robert L Krawitz 16 Aug 13:08
       GIMP print dialog issues Brian Thomason 16 Aug 19:34
       GIMP print dialog issues Sven Neumann 17 Aug 10:39
        GIMP print dialog issues Robert L Krawitz 17 Aug 13:07
         GIMP print dialog issues Sven Neumann 18 Aug 22:36
          GIMP print dialog issues Robert L Krawitz 19 Aug 01:40
20050816084208.GA6768@epict... 07 Oct 20:24
  GIMP print dialog issues Brian Thomason 16 Aug 19:33
   GIMP print dialog issues Bill Kendrick 16 Aug 20:19
    GIMP print dialog issues Robert L Krawitz 17 Aug 02:24
     GIMP print dialog issues Bill Kendrick 17 Aug 02:31
     GIMP print dialog issues Brian Thomason 17 Aug 02:42
      GIMP print dialog issues Robert L Krawitz 17 Aug 03:46
87wtmkigy1.fsf@hardknott.ho... 07 Oct 20:24
  GIMP print dialog issues Robert L Krawitz 18 Aug 04:06
Brian Thomason
2005-08-16 01:12:17 UTC (over 19 years ago)
I am packaging up gimp 2.2.8 for Linspire and have noticed some strange issues in the print dialog that my non-existent C skills have been unable to resolve.
I'm not the best in the world at describing problems, so I have attached a screenshot to help out a bit.
Problem 1:
When the print dialog is open, the orientation is set to "Auto", which is good, but none of the default position indentions are set. (Left, Right, left Border, etc...) For the common user, he will just hit print when presented with the dialog, and this will simply fail as it is.
Problem 2:
Consequently, as a result of problem 1, the preview pane is "distorted".
Changing the orientation, alignment, or any such settings solves the problem, but I am unable to achieve these same results by manually calling the various callback functions associated with these actions. I either end up with a segfault, or simply nothing being changed.
Any help would be greatly appreciated.
-Brian
Robert L Krawitz
2005-08-16 01:22:17 UTC (over 19 years ago)
Date: Mon, 15 Aug 2005 16:12:17 -0700 From: Brian Thomason
Problem 1:
I'm the project lead for Gutenprint. Can you describe for me more specifically what you mean? Why will it "fail as it is"?
Problem 2:
What are you trying to do here?
michael chang
2005-08-16 01:30:54 UTC (over 19 years ago)
Which printing system does Linspire use? (e.g. CUPS, BSD, etc.) Does it make one of it's own to make it similar to Windows?
Brian Thomason
2005-08-16 01:34:10 UTC (over 19 years ago)
We use CUPS. (No modifications, other than cosmetics)
-Brian
michael chang
2005-08-16 01:38:02 UTC (over 19 years ago)
With or without BSD daemons?
Robert L Krawitz
2005-08-16 01:38:03 UTC (over 19 years ago)
Date: Mon, 15 Aug 2005 16:28:54 -0700 From: Brian Thomason
>I'm the project lead for Gutenprint. Can you describe for me more >specifically what you mean? Why will it "fail as it is"?
Because there are no values automatically filled in to the Left, Right, Left Border, Top, and Right Border fields.
Thanks for sending me the screenshot.
> Problem 2: >
> Consequently, as a result of problem 1, the preview pane is "distorted". >
> Changing the orientation, alignment, or any such settings solves the > problem, but I am unable to achieve these same results by manually > calling the various callback functions associated with these actions. I > either end up with a segfault, or simply nothing being changed. >
> Any help would be greatly appreciated. >
I'm simply trying to have these values filled in by default, and have the image vertically aligned, by default.
It would help if I had actually attached the image. (doh!)
Many thanks for the fast response.
I've never seen anything like this, with the dimension/positioning boxes not filled in, even when using the Postscript driver without a PPD file. Which release of Gimp-Print are you using (4.2.7 is the most recent, and last, 4.2 release)? Are you using the unmodified source code? Can you supply a reproducible test case?
Robert L Krawitz
2005-08-16 01:39:20 UTC (over 19 years ago)
Date: Mon, 15 Aug 2005 19:30:54 -0400 From: michael chang
On 8/15/05, Brian Thomason wrote: > I am packaging up gimp 2.2.8 for Linspire and have noticed some strange
> When the print dialog is open, the orientation is set to "Auto", > which is good, but none of the default position indentions are > set. (Left, Right, left Border, etc...) For the common user, he > will just hit print when presented with the dialog, and this will > simply fail as it is.
That shouldn't have any effect here. Gimp-Print doesn't really care what the underlying spooling system is.
michael chang
2005-08-16 01:40:12 UTC (over 19 years ago)
I am packaging up gimp 2.2.8 for Linspire and have noticed some strange Right, left Border, etc...) For the common user, he will just hit print when presented with the dialog, and this will simply fail as it is.
At odd times, if the user doesn't flatten the image before printing, it will only print the current layer. And he'll wonder why half his image is gone. [I can't remember what version of GIMP/GIMP-Print this is in.] Some who are prompted for auto-flattening-export think it will perminantly flatten their image, and look for a work around.
Are you packing gutenprint/gimpprint also?
michael chang
2005-08-16 01:41:15 UTC (over 19 years ago)
How does it contact the spooling system? Or does it use specific methods for each printing system?
Brian Thomason
2005-08-16 01:43:55 UTC (over 19 years ago)
With the BSD daemons. (cupsys-bsd)
-Brian
Brian Thomason
2005-08-16 01:50:14 UTC (over 19 years ago)
Yes, I am using 4.2.7, completely unmodified. If you have a spare box to install Linspire 5.0 on, absolutely. (Debian Sarge might also suffice, but I'm not sure.)
Simply installing gimp 2.2.8, creating an image, of any size, and selecting "Print" from the file menu of that image reproduces this.
-Brian
Brian Thomason
2005-08-16 01:52:33 UTC (over 19 years ago)
Not unless needed. We've been happy with 4.2.7 up to this point.
-Brian
Akkana Peck
2005-08-16 02:24:22 UTC (over 19 years ago)
michael chang writes:
In CVS GIMP, the export dialog does say, "The export conversion won't modify your original image," so at least users shouldn't be worried about that (if they read the dialog).
But I'm not sure why the dialog exists in the first place. Is there any reason the user needs to be prompted for this? It doesn't modify the current image, it's just a temporary thing for printing. Clicking Ignore seems to do the same thing (at least on Linux and current CVS) as clicking Export, so the user doesn't have any useful choice to make here, just a confusion between two apparently identical choices (or Cancel). Why not just do the conversion without bothering the user about it?
...Akkana
Robert L Krawitz
2005-08-16 03:40:28 UTC (over 19 years ago)
Date: Mon, 15 Aug 2005 19:41:15 -0400 From: michael chang
On 8/15/05, Robert L Krawitz wrote: > That shouldn't have any effect here. Gimp-Print doesn't really care > what the underlying spooling system is.
It just uses the lpr or lp command -- nothing fancy.
Robert L Krawitz
2005-08-16 03:44:10 UTC (over 19 years ago)
Date: Mon, 15 Aug 2005 16:52:33 -0700 From: Brian Thomason
Cc: gimp-developer@lists.xcf.berkeley.edu
>>>On 8/15/05, Brian Thomason wrote: >>>
>>>>I am packaging up gimp 2.2.8 for Linspire and have noticed some strange >>>>Right, left Border, etc...) For the common user, he will just hit print >>>>when presented with the dialog, and this will simply fail as it is. >>>>
>At odd times, if the user doesn't flatten the image before printing, >it will only print the current layer. And he'll wonder why half his >image is gone. [I can't remember what version of GIMP/GIMP-Print this >is in.] Some who are prompted for auto-flattening-export think it >will perminantly flatten their image, and look for a work around. >
Are you using the 4.2.7 tarball from gimp-print.sourceforge.net?
Robert L Krawitz
2005-08-16 03:46:56 UTC (over 19 years ago)
Date: Mon, 15 Aug 2005 16:50:14 -0700 From: Brian Thomason
>I've never seen anything like this, with the dimension/positioning >boxes not filled in, even when using the Postscript driver without a >PPD file. Which release of Gimp-Print are you using (4.2.7 is the >most recent, and last, 4.2 release)? Are you using the unmodified >source code? Can you supply a reproducible test case?
I don't have a spare box.
I've never seen this kind of problem, and this is the first report I've heard of anything of this sort. I'm cc'ing Roger Leigh, our Debian expert.
Roger, Brian has a rather odd problem whereby when he starts the Print plugin on a fresh image he gets completely empty positioning boxes (nothing filled in for any of the position/sizing boxes). I'll send you a screenshot under separate cover.
Brian Thomason
2005-08-16 04:30:35 UTC (over 19 years ago)
Thanks for the continued help
One thing to note, Roger, is that this is only prevalent in our packaging of gimp 2.2.8, as Debian's package, last I checked, has printing explicitly disabled for some reason. (Perhaps for the same problem, but I doubt it) I'm sure you have far more insight on this than I do, however.
-Brian
Robert L Krawitz
2005-08-16 13:08:40 UTC (over 19 years ago)
Date: Mon, 15 Aug 2005 19:30:35 -0700 From: Brian Thomason
>Roger, Brian has a rather odd problem whereby when he starts the >Print plugin on a fresh image he gets completely empty positioning >boxes (nothing filled in for any of the position/sizing boxes). >I'll send you a screenshot under separate cover.
This helps. The GIMP actually includes its own copy of the Print plugin, but I don't know exactly what source that's based on. What you might try is using --disable-print with the GIMP, and configuring Gimp-Print with --enable-gimp (which builds the Print plugin out of the Gimp-Print source).
Brian Thomason
2005-08-16 19:33:56 UTC (over 19 years ago)
gimp 2.2.8 is from Debian unstable. If you use this, you also need to install the "gimp-print" package, which provides the Print plug-in.
http://packages.debian.org/unstable/graphics/gimp-print
This is due to uploading Gutenprint (new Gimp-Print) to unstable, which has been in use for just over a month. This is a beta release candidate, so you might not want to make the switch just yet in Linspire. This should be the proper release by the time etch is released.
For Linspire, simply re-enabling the gimp copy of the Print plug-in at configure time, and adding back the libgimpprint1-dev build dependency should get you a working plugin again.
Thanks Roger,
We did that, and the plugin works, but the orientation/position fields are all empty upon launching it.
-Brian
Roger
Brian Thomason
2005-08-16 19:34:49 UTC (over 19 years ago)
I'll give that a swing. Thanks!
-Brian
Bill Kendrick
2005-08-16 20:19:57 UTC (over 19 years ago)
FWIW, I fired up Gimp on my Debian/etch box last night, drew a picture, hit 'Print', and the dialog that appeared also lacked values in the position fields (until I played with the orientation pulldown or the scale slider).
However, if I printed while they were blank, it seemed to print ok, full-page on US letter.
I can't recall what versions of anything I was using, but it's whatever's the latest in Testing (etch) as of a couple days ago.
-bill!
Robert L Krawitz
2005-08-17 02:24:36 UTC (over 19 years ago)
Date: Tue, 16 Aug 2005 11:19:57 -0700 From: Bill Kendrick
On Tue, Aug 16, 2005 at 10:33:56AM -0700, Brian Thomason wrote: > We did that, and the plugin works, but the orientation/position fields > are all empty upon launching it.
Does this only happen with an unsaved image?
Bill Kendrick
2005-08-17 02:31:16 UTC (over 19 years ago)
Oh, I didn't think to check with a saved image. It did happen with an unsaved one, though. I can look tonight.
(I've got Gimp on WinXP at work, so that doesn't help me :^) )
-bill!
Brian Thomason
2005-08-17 02:42:01 UTC (over 19 years ago)
On my Linspire machine, it happens with both saved and unsaved images.
-Brian
Robert L Krawitz
2005-08-17 03:46:13 UTC (over 19 years ago)
Date: Tue, 16 Aug 2005 17:42:01 -0700 From: Brian Thomason
> Date: Tue, 16 Aug 2005 11:19:57 -0700 > From: Bill Kendrick
> On Tue, Aug 16, 2005 at 10:33:56AM -0700, Brian Thomason wrote: > > We did that, and the plugin works, but the orientation/position fields > > are all empty upon launching it. >
> FWIW, I fired up Gimp on my Debian/etch box last night, drew a > picture, hit 'Print', and the dialog that appeared also lacked > values in the position fields (until I played with the orientation > pulldown or the scale slider). >
> However, if I printed while they were blank, it seemed to print ok, > full-page on US letter.
> I can't recall what versions of anything I was using, but it's > whatever's the latest in Testing (etch) as of a couple days ago. >
I can't reproduce this at all with 5.0. I'm not able to get 4.2 to run right now for some reason.
2005-08-17 10:39:39 UTC (over 19 years ago)
Him
Robert L Krawitz writes:
Which is actually what debian is doing (at least in sid). They recently switched from the included plug-in to the one that comes with gutenprint. I have been very disappointed to find out that none of the user interface improvements that we have done to the Print plug-in over the last years have been incorporated into that version. Basically the Print dialog looks like crap now.
Robert L Krawitz
2005-08-17 13:07:31 UTC (over 19 years ago)
Date: Wed, 17 Aug 2005 10:39:39 +0200
> This helps. The GIMP actually includes its own copy of the Print > plugin, but I don't know exactly what source that's based on. > What you might try is using --disable-print with the GIMP, and > configuring Gimp-Print with --enable-gimp (which builds the Print > plugin out of the Gimp-Print source).
1) I don't remember anyone ever feeding them back to us. Mitch did some improvements once, years ago, but no one's ever contacted us since.
2) We're not interested in any changes to the 4.2-based plugin at this point; 5.0 is the wave of the future. They're different enough that changes to one won't port very easily to the other.
3) That's what happens when nobody steps forward to maintain the plugin and I have to do UI stuff. The best way to utilize me for UI programming is to take whatever I do and invert it.
Robert L Krawitz
2005-08-18 04:06:03 UTC (over 19 years ago)
Date: Wed, 17 Aug 2005 18:58:14 +0100
Sven Neumann writes:
> Robert L Krawitz writes: >
>> This helps. The GIMP actually includes its own copy of the Print >> plugin, but I don't know exactly what source that's based on. What >> you might try is using --disable-print with the GIMP, and configuring >> Gimp-Print with --enable-gimp (which builds the Print plugin out of >> the Gimp-Print source).
> Which is actually what debian is doing (at least in sid). They > recently switched from the included plug-in to the one that comes with > gutenprint. I have been very disappointed to find out that none of the > user interface improvements that we have done to the Print plug-in > over the last years have been incorporated into that version. > Basically the Print dialog looks like crap now.
I wanted to do this, but the fact that we have to support both GTK+-1.2 (for Cinepaint) and GTK+-2.0 (for Gimp) versions of the codebase caused serious problems keeping the two versions in sync. It also meant that the 2.0 version was basically restricted to using the 1.2 era features, otherwise syncing changes would become impossible. All I could do was a minimal conversion from 1.2 to 2.0.
I don't see why we necessarily have to keep the capabilities of the two in sync. The 1.2 plugin already supports all of the 5.0 capabilities, and keeping them in sync doesn't really reduce the testing burden. It might be a bit late to do it now, but if you want to get started, go ahead.
The only 1.2 clients we need to be concerned with are the GIMP and Cinepaint. The GIMP folks have no interest in 1.2, and if Cinepaint wants to improve it, they can maintain it.
As soon as 5.0.0 is released and stable branched in CVS, I'd like to rip out the 1.2 UI code and do some real work on the 2.0 code, which will include merging the Gimp changes over, as well as splitting it out into discrete GObjects; I'm not too happy with the current slew of global variables.
That code really is rather brutal, isn't it...
2005-08-18 22:36:22 UTC (over 19 years ago)
You need them fed to you? Are you serious?
The gimp-print plug-in in Debian sid is the 5.0 based plug-in, isn't it?
Well, I offered my help more than once and asked you to transfer maintainership of the plug-in completely to us. That never happened and at some point I definitely lost interest. At the moment I am more inclined to drop the print plug-in from the GIMP tree entirely. Or perhaps replace it with a simple one that is based on libgnomeprint / libgnomeprintui.
Robert L Krawitz
2005-08-19 01:40:05 UTC (over 19 years ago)
Date: Thu, 18 Aug 2005 22:36:22 +0200
> 1) I don't remember anyone ever feeding them back to us. Mitch did > some improvements once, years ago, but no one's ever contacted us > since.
Personally I had no idea that you ever did anything but port it otherwise unchanged to the GIMP 2.x. At one point, Mitch did make some improvements, which he gave back to us, but I never heard of any further work.
> 2) We're not interested in any changes to the 4.2-based plugin at this > point; 5.0 is the wave of the future. They're different enough > that changes to one won't port very easily to the other.
I don't know. The Linspire dialog is definitely 4.2, not 5.0. The one you folks have in the GIMP is based on 4.2.
> 3) That's what happens when nobody steps forward to maintain the > plugin and I have to do UI stuff. The best way to utilize me for > UI programming is to take whatever I do and invert it.
The idea was that we'd turn it over to you when 5.0 was released. Regardless, we've pretty clearly dropped the ball here, since 5.0 has taken a lot longer than plan. I don't entirely regret that, since we've done some important things, but facts is facts and I don't blame you for losing interest in it.
