GIMP Dynamic Text
7 of 7 messages available
GIMP Dynamic Text Andrei Simion 07 Jul 17:59
  GIMP Dynamic Text Sven Neumann 07 Jul 22:31
   GIMP Dynamic Text Andrei Simion 08 Jul 06:21
    GIMP Dynamic Text Owen Cook 08 Jul 07:37
     GIMP Dynamic Text Andrei Simion 08 Jul 19:48
      GIMP Dynamic Text Sven Neumann 09 Jul 01:37
       GIMP Dynamic Text Andrei Simion 10 Jul 16:58
Andrei Simion
2005-07-07 17:59:09 UTC (almost 20 years ago)
GIMP Dynamic Text
I'd like to use the below GIMP Dynamic Text with Gimp-Perl, but I cannot find any documentation on it.
Regards, Andrei
2005-07-07 22:31:28 UTC (almost 20 years ago)
GIMP Dynamic Text
Andrei Simion writes:
What is the below GIMP Dynamic Text?
Andrei Simion
2005-07-08 06:21:48 UTC (almost 20 years ago)
GIMP Dynamic Text
Is this: http://registry.gimp.org/plugin?id=337
Andrei
Owen Cook
2005-07-08 07:37:14 UTC (almost 20 years ago)
GIMP Dynamic Text
That is a Gimp-1.2 plug-in and if you are using Gimp-2.x?, it will not work.
Owen
Andrei Simion
2005-07-08 19:48:48 UTC (almost 20 years ago)
GIMP Dynamic Text
And there is other tool like GIMP Dynamic Text to work in Gimp 2.2? I need basically to wrap the text when the line is bigger than the size of the layer.
Thanks,
Andrei
Owen
2005-07-09 01:37:06 UTC (almost 20 years ago)
GIMP Dynamic Text
The new text tool will attempt to load GIMP Dynamic Text layers from your old XCF files. It also provides multiline text. What it doesn't provide yet, is the ability to specify a fixed layer width and have the text broken wrapped into that. That is however planned.
Since I seem not to get around to implement it, perhaps someone else wants to look into adding the missing pieces? Quite a bit of the required functionality is already there, since this feature has always been foreseen. What's missing is mostly the tool code. I haven't looked at this in detail, but I think it should be possible to add this by deriving the text tool from the new rectangle tool. If anyone is interested, let me know. I will then try to explain the text properties that exist for this purpose. I hope that the existing text infrastructure will be capable of handling this feature w/o any incompatible changes to the gimp-text parasite.
Andrei Simion
2005-07-10 16:58:20 UTC (almost 20 years ago)
GIMP Dynamic Text
Thanks for the update.
As long as it is not implemented yet, I'd like to use GIMP Dynamic Text.
Does anybody knows where I can find some documentation to use its Perl API?
Regards, Andrei
