ANNOUNCE: GNU Image Manipulation Program versions 2.2.8 and 2.3.2
ANNOUNCE: GNU Image Manipulation Program versions 2.2.8 and 2.3.2 Sven Neumann 02 Jul 15:39
2005-07-02 15:39:16 UTC (almost 20 years ago)
there are two new releases to announce this time. The release of 2.2.8 is already a few days old but still worth mentioning. GIMP 2.2.8 is a bug-fix release in the stable GIMP 2.2 series. Here's a list of changes since 2.2.7:
Bugs fixed in GIMP 2.2.8 ========================
- fixed possible crash in plug-ins-query PDB function - fixes to Script-Fu server mode on Win32 - fixed possible crash in win32 gimptool variant - plugged a tiny memleak in the image display code - plugged a tiny memleak in libgimpwidgets - attempt to fix calling the web-browser on win32 (bug #171200) - fixed loading of images in help-browser plug-in on win32 - fixed zoom offsets if dot-for-dot mode is disabled (bug #306476) - fixes to Gfig parasite loading - disabled buggy gimprc option stingy-memory-use (bug #306617) - don't try to create a preview for a non-existant image file (bug #307672)
- fixed bug in Retinex plug-in (bug #157915) - fixed bug in Newsprint plug-in (bug #161573) - fixed bug in Shift plug-in (bug #308748) - fixed bug in Grid plug-in (bug #308754)
For the brave and curious, GIMP 2.3.2 is a snapshot of current development towards GIMP 2.4. Compared to 2.3.1, this release includes the following changes:
Changes in GIMP 2.3.2 =====================
- more standard way of dealing with translation of the startup tips - allow to use the selected font in the text tool's text editor - some minor UI changes for HIG compliance - redid the framework that deals with installing desktop files - started to reorganize menus, mainly plug-ins and scripts - renamed "Scatter RGB" and "Scatter HSV" to "RGB Noise" and "HSV Noise" - allow to clear the document history - don't normalize the result in the Laplace plug-in (bug #306874) - ported FractalExplorer GUI to GtkTreeView, getting rid of the last XPM icons that were being used - added an option to Motion Blur to blur outwards - added support for the proposed ICC Profiles In X Specification - added new widget GimpEnumLabel to libgimpwidgets - let the lcms display filter module show information about the used color profiles
- improved drawing of the brush outline - fixed build of Python language binding on Win32 - allow plug-ins to access the user's color management configuration - added new widget GimpPageSelector to libgimpwidgets - reenabled the Debug menu
- load and save ICC color profiles from/to JPEG images - bug fixes and code cleanup
If you want to try the development snapshot, please read the release notes at http://gimp.org/release-notes/gimp-2.3.html
The source code for GIMP is available from ftp.gimp.org or one of the mirrors listed at:
http://gimp.org/downloads/
Thanks to all the people who have helped to make these release happen. Happy GIMPing,
