preview for scrip-fu plugin?
preview for scrip-fu plugin? pepster 29 Jun 02:01
  preview for scrip-fu plugin? Kevin Cozens 29 Jun 05:39
   preview for scrip-fu plugin? pepster 29 Jun 13:30
    preview for scrip-fu plugin? Nathan Summers 29 Jun 15:57
     preview for scrip-fu plugin? pepster 29 Jun 22:46
pepster
2005-06-29 02:01:54 UTC (over 20 years ago)
Say I have a scrip-fu plugin (I am thinking about wrap sharp), and I want to add a preview window to make it more useful.
Does it mean I must re-write the plugin in C, or is there an easier way?
Thanks, Joseph
Kevin Cozens
2005-06-29 05:39:24 UTC (over 20 years ago)
You would have to re-write it in C. There is no easy way to add a preview window to Script-Fu.
pepster
2005-06-29 13:30:03 UTC (over 20 years ago)
I tried to make a start but facing immediate problems. Would appreciate some pointers -
1. The scm code calls the (pdb) plugin plug_in_edge. I am not sure how my C plugin can make a call to another plugin??
2. The preview need to render just a sub-region of the preview drawable - but a plug-in such as plug_in_edge need a drawable as argument. How does one turn a region into a new drawable?
Thanks, Joseph
Nathan Summers
2005-06-29 15:57:16 UTC (over 20 years ago)
The way to do this is with one of the gimp_run_procedure functions, but in this case edge-detection is trivial enough that it doesn't make sense to call a separate plug-in to do it. In fact, copying the existing edge-detection plug-in might be the best way to start.
Rockwalrus
pepster
2005-06-29 22:46:37 UTC (over 20 years ago)
Rockwalrus
And then re-implement gausian filtering, and then re-implement map bumping and ... - do you get the picture?
Anyway, gimp_run_procedure2 it is.
Now, how do I create a drawable from the region on the fly?
Thanks, Joseph
