Re : [Debian Sid issue] Failed to compile the CVS
Failed to compile the CVS Jean-Luc Coulon (f5ibh) 25 Jun 12:36
  [Debian Sid issue] Failed to compile the CVS Jean-Luc Coulon (f5ibh) 25 Jun 14:30
   [Debian Sid issue] Failed to compile the CVS Manish Singh 25 Jun 22:13
    Re : [Debian Sid issue] Failed to compile the CVS Jean-Luc Coulon (f5ibh) 25 Jun 23:18
2005-06-25 12:36:26 UTC (almost 20 years ago)
I got:
gcc -g -O2 -Wall -o .libs/aa aa.o ../../libgimp/.libs/libgimpui-2.0.so libgimpconfig/.libs/libgimpconfig-2.0.so ../../libgimpwidgets/.libs/libgimpwidgets-2.0.so ../../libgimp/.libs/libgimp-2.0.so ../../libgimpcolor/.libs/libgimpcolor-2.0.so ../../libgimpmath/.libs/libgimpmath-2.0.so ../../libgimpbase/.libs/libgimpbase-2.0.so /usr/lib/libaa.so /usr/lib/libgtk-x11-2.0.so /usr/lib/libgdk-x11-2.0.so /usr/lib/libatk-1.0.so /usr/lib/libgdk_pixbuf-2.0.so -lm /usr/lib/libpangoxft-1.0.so /usr/lib/libpangox-1.0.so /usr/lib/libpango-1.0.so /usr/lib/libgobject-2.0.so /usr/lib/libgmodule-2.0.so -ldl /usr/lib/libglib-2.0.so -Wl,--rpath -Wl,/opt/gimp-2.3.2/lib
aa.o(.text+0x379): In function `save_aa': /usr/local/src/gimp/gimp-2.3.2-cvs20050625/plug-ins/common/aa.c:250: undefined reference to `save_d'
collect2: ld returned 1 exit status
make[3]: *** [aa] Erreur 1
make[3]: Leaving directory
`/usr/local/src/gimp/gimp-2.3.2-cvs20050625/plug-ins/common'
Do I missed something ?
Jean-Luc
2005-06-25 14:30:02 UTC (almost 20 years ago)
Some symbols (including save_d) are missing in the latest update of aalib
Regards
Jean-Luc
Manish Singh
2005-06-25 22:13:15 UTC (almost 20 years ago)
Yes, the debian maintainer made a bogus change:
http://bugs.debian.org/cgi-bin/bugreport.cgi?bug=315606
Downgrade aalib for now.
-Yosh
2005-06-25 23:18:01 UTC (almost 20 years ago)
aalib
Done, thanks snapshot.debian.net ;-)
-Yosh
Thank you
J-L
