Screenshot again: capture a window withoutdecoration
Screenshot again: capture a window without decoration Jean-Luc Coulon (f5ibh) 05 Jun 09:40
Screenshot again: capture a window withoutdecoration William Skaggs 05 Jun 17:59
2005-06-05 09:40:25 UTC (almost 20 years ago)
The screen capture pug-in doesnt take account if "capture the decoration" is checked or not. The window is always captured with the decoration.
Regards
Jean-Luc
William Skaggs
2005-06-05 17:59:04 UTC (almost 20 years ago)
Hmm. Very odd. This was of course tested before I committed it, but as far as I can tell from ViewCVS, the code for this ought *never* to have worked. Anyway, fixed now in HEAD. Thanks for the report.
2005-06-05 Bill Skaggs
* plug-ins/common/screenshot.c: make " no decorations" option work; problem pointed out by Jean-Luc Coulon on dev list.
I must add, however: it is very nice to be told about bugs in this way. It would be even nicer if you could report them using Bugzilla.
-- Bill
