CVS, screenshot plugin crash
CVS, screenshot plugin crash Jean-Luc Coulon 02 Jun 17:31
CVS, screenshot plugin crash William Skaggs 02 Jun 19:23
  CVS, screenshot plugin crash Simon Budig 02 Jun 19:38
CVS, screenshot plugin crash William Skaggs 02 Jun 20:09
Jean-Luc Coulon
2005-06-02 17:31:07 UTC (almost 20 years ago)
If I do:
- Acquire - Screenshot
- the sectected region
The plugin crash with a popup : Plud-in crashed: "screenshot"
I've in the xterm from when I launched gimp: The program 'screenshot' received an X Window System error. This probably reflects a bug in the program. The error was 'BadAccess (attempt to access private resource denied)'. (Details: serial 5216 error_code 10 request_code 33 minor_code 0) (Note to programmers: normally, X errors are reported asynchronously; that is, you will receive the error a while after causing it. To debug your program, run it with the --sync command line option to change this behavior. You can then get a meaningful backtrace from your debugger if you break on the gdk_x_error() function.)
(gimp-2.3:29235): Gimp-Plug-In-WARNING **: gimp-2.3: plug_in_flush(): error:
Broken pipe
The lastest vesion of the CVS with a non-crashing screenshot plugin was the
one with these data on top of the Changelog: 2005-05-30 Sven Neumann
* plug-ins/common/screenshot.c: capitalization and mnemonics.
2005-05-29 Sven Neumann
* app/widgets/gimpdnd.c (gimp_dnd_get_color_icon): pass GIMP_COLOR_AREA_CHECKS_SMALL instead of TRUE for the type of the GimpColorArea.
* app/widgets/gimpcoloreditor.c: added a "context" property.
* libgimpwidgets/gimpcolorarea.c (gimp_color_area_set_color): always use gimp_rgba_distance(), regardless of the area's type.
The day after, there was a changed in the screenshot. Dunnon if it is related :
2005-05-31 Sven Neumann
* plug-ins/common/screenshot.c (select_window_x11): use XGrabKey() to grab the Escape key instead of doing a full keyboard grab.
Regards
Jean-Luc
William Skaggs
2005-06-02 19:23:28 UTC (almost 20 years ago)
I get the same result. Looking at the man pages, this apparently happens if the key being grabbed has already been grabbed by something else -- but there does not seem to be any way to tell whether a given key has already been grabbed. Which kind of sucks.
There's a good chance that the window manager comes into play here. I am using Metacity with FC2 -- what about you?
-- Bill
Simon Budig
2005-06-02 19:38:18 UTC (almost 20 years ago)
If XGrabKey might fail you can wrap it similiar to this:
gdk_error_trap_push (); XGrabKey (GDK_DISPLAY_XDISPLAY (data->display), data->hot_keycode,
AnyModifier,
GDK_WINDOW_XWINDOW (data->root), TRUE,
GrabModeAsync,
GrabModeAsync);
gdk_flush ();
if (gdk_error_trap_pop ())
g_printerr ("could not grab Hotkey. Aborting...\n"); exit (1);
Bye,
Simon
William Skaggs
2005-06-02 20:09:37 UTC (almost 20 years ago)
AnyModifier,
GrabModeAsync,
GrabModeAsync);
gdk_flush ();
Thanks for the hint. I tried wrapping the XGrabKey call in a gdk_error_trap_push/pop pair, and it seems to do the trick. (I don't see any reason for the plug-in to bail out just because the ESC key can't be grabbed.)
From the ChangeLog for HEAD:
2005-06-01 Bill Skaggs
* plug-ins/common/screenshot.c: trap errors when running XGrabKey, to prevent bail-out on BadAccess error as reported by Jean-Luc Coulon on developers list; solution suggested by Simon Budig.
It would probably have been better to do all this via Bugzilla, by the way.
-- Bill
