[Fwd: Re: [maybe OT?] Code excerpts from the GIMP]
[Fwd: Re: [maybe OT?] Code excerpts from the GIMP] Tom Copeland 03 May 02:35
Tom Copeland
2005-05-03 02:35:12 UTC (almost 20 years ago)
-------- Forwarded Message --------
gimp-2.2.4/app/core/gimppreviewcache.c uses a GSList as a sort of size-based queue; it holds image previews in a GSList and uses g_slist_insert_sorted to insert the smaller images first. Oddly, another function in the same file trims the cache by iterating over the same GSList and comparing each item to find the smallest one to remove. Might be a possibility for some optimization there.
The function preview_cache_remove_smallest() which is used to trim the cache actually uses a different comparison than what is used to keep the list sorted. Whether this is what the author intended, I don't know.
Ah, you're right, it uses the area vs an x1 > x2 and y1 > y2 comparison. I've corrected that comment, thanks much!
http://infoether.com/~tom/gimp_snippets.html
It might be of interest to your readers to also include GimpList as an implementation of the GimpContainer class.
That is interesting. Backed by a GList, and sortable, and does unique names too, huh? Pretty cool.
Thanks,
Tom
