[maybe OT?] Code excerpts from the GIMP
[maybe OT?] Code excerpts from the GIMP Tom Copeland 02 May 23:23
  [maybe OT?] Code excerpts from the GIMP Simon Budig 03 May 00:06
   [maybe OT?] Code excerpts from the GIMP Tom Copeland 03 May 02:18
  [maybe OT?] Code excerpts from the GIMP Sven Neumann 03 May 00:47
  [maybe OT?] Code excerpts from the GIMP Sven Neumann 03 May 01:17
  [maybe OT?] Code excerpts from the GIMP Tom Copeland 30 Jun 20:53
Tom Copeland
2005-05-02 23:23:01 UTC (over 20 years ago)
Howdy -
Here's a bit of GIMP "code publicity" I thought folks might be interested in. I'm working on a tutorial for IBM's developerWorks site on the GLib collections - GSList, GHashTable, GTree, and all that. As part of the tutorial, I'm picking out excerpts of various collection type usages from a couple of nice open source apps - like the GIMP.
Here's a list of the references to the GIMP that I've currently got in the article:
http://infoether.com/~tom/gimp_snippets.html
If anyone has any suggestions/corrections to the descriptions of these usages, please email me at tom@infoether.com (or here if you think it's on-topic enough).
Many thanks,
Tom Copeland tom@infoether.com
Simon Budig
2005-05-03 00:06:05 UTC (over 20 years ago)
I just want to make you aware that the example in gimp-2.2.4/app/base/boundary.c does not actually get used currently. If you're curious: this algorithm is a modified version of the douglas peucker algorithm for line simplification. A discussion why this code is currently unused can be found here: http://bugzilla.gnome.org/show_bug.cgi?id=50730
Feel free to ask me about this code and the vector-related stuff in your examples.
Bye,
Simon
2005-05-03 00:47:56 UTC (over 20 years ago)
2005-05-03 01:17:40 UTC (over 20 years ago)
Tom Copeland writes:
gimp-2.2.4/app/core/gimppreviewcache.c uses a GSList as a sort of size-based queue; it holds image previews in a GSList and uses g_slist_insert_sorted to insert the smaller images first. Oddly, another function in the same file trims the cache by iterating over the same GSList and comparing each item to find the smallest one to remove. Might be a possibility for some optimization there.
The function preview_cache_remove_smallest() which is used to trim the cache actually uses a different comparison than what is used to keep the list sorted. Whether this is what the author intended, I don't know.
It might be of interest to your readers to also include GimpList as an implementation of the GimpContainer class.
Tom Copeland
2005-05-03 02:18:40 UTC (over 20 years ago)
That's very interesting, thank you! I understand your comment about "failing in a predictable way"; such are the vagaries of programming....
But it sounds like it may well be used at some point, and it illustrates the GArray nicely, so I think I'll leave it in there for the tutorial.
Thanks very much indeed!
Yours,
Tom
Tom Copeland
2005-06-30 20:53:58 UTC (over 20 years ago)
On Mon, 2005-05-02 at 17:23 -0400, Tom Copeland wrote:
Howdy -
This tutorial, complete with Gimp Glib API usage code samples, is up on the IBM developerWorks web site now:
http://www-130.ibm.com/developerworks/linux
IBM has redone their tutorial format, so there's not as much clicking from slide to slide as there used to be, which is nice.
Hope folks find it interesting!
Yours,
Tom
