Auntie Alias plugin
Auntie Alias plugin Adam D. Moss 25 Mar 18:54
  Auntie Alias plugin Michael Natterer 10 May 11:08
   Auntie Alias plugin Adam D. Moss 10 May 18:15
Auntie Alias plugin Matt 05 Apr 22:54
  Auntie Alias plugin Adam D. Moss 06 Apr 11:59
Adam D. Moss
2005-03-25 18:54:00 UTC (over 20 years ago)
Auntie Alias plugin
Hi guys and gals,
I recently wrote this plugin for my own amusement; someone else might find a reasonably use for it.
It probably does something very similar to the 'antialias' plugin for GIMP 1.2, except this is for GIMP 2.0 (2.X?) and uses a different algorithm (I haven't compared results).
http://icculus.org/~aspirin/gimp/auntiealias/
--Adam
Matt
2005-04-05 22:54:33 UTC (over 20 years ago)
Auntie Alias plugin
Is it possible to use this under win32?
Adam D. Moss
2005-04-06 11:59:46 UTC (over 20 years ago)
Auntie Alias plugin
It's entirely possible, if someone wants to compile it up for win32. I'm not equipped to do so myself.
--Adam
Michael Natterer
2006-05-10 11:08:19 UTC (about 19 years ago)
Auntie Alias plugin
On Fri, 2005-03-25 at 17:54 +0000, Adam D. Moss wrote:
Hi guys and gals,
Hi Adam,
yesterday, i stumbled across this mail, and it looks as if this plug-in is doing exactly the right thing to lineart images.
I "ported" it to 2.4 API and codingstylized it a bit:
http://mitch.gimp.org/auntiealias.c
Since we consider including it, I have some questions:
- The licensing would be changed to GPL, would that be ok? - Do you have any link to that Scale3X algorithm? I would be nice to include an URL in the help. - Is the behavior on images with alpha intentional? (it only affects opaque areas, but does not antialias between opaque and transparent parts)
- Do you maybe have a newer version around?
ciao, --mitch
Adam D. Moss
2006-05-10 18:15:03 UTC (about 19 years ago)
Auntie Alias plugin
Hi there!
It wouldn't be my first choice as I took pains to non-taint it in the first place, but re-licensing to GPL is one of the things implicitly permitted by the existing license so if you must, do so.
This was *probably* the page I used as reference: http://scale2x.sourceforge.net/algorithm.html though to be fair that's just a page of pseudocode not especially clearer than the plugin's. :)
It refuses to antialias between not-entirely-transparent and entirely-transparent to avoid the possibility of giving some partial opacity to undefined colours. This was intentional but heavyhandedly implemented; there is likely to be a more delicate compromise.
I'm afraid not; it was a one-day fire-and-forget experiment. Since there's some interest I'll have a quick hack to change the moronic subsambling kernel right now (n.b. that's not related to the alpha thing) and if the results are better I'll submit a patch.
Cheers,
--adam
