ANNOUNCE: Gutenprint 5.0.0-beta3
ANNOUNCE: Gutenprint 5.0.0-beta3 | Tyler Blessing | 13 Feb 17:24 |
Welcome to Gutenprint 5.0.0-beta3! Please read these release notes carefully.
Gutenprint, formerly named Gimp-Print, is a suite of printer drivers that may be used with most common UNIX print spooling systems, including CUPS, lpr, LPRng, or others. These drivers provide high quality printing for UNIX (including Macintosh OS X 10.2 and 10.3) and Linux systems that in many cases equal or exceed proprietary vendor-supplied drivers in quality and functionality, and can be used for demanding printing tasks requiring flexibility and high quality. This software package includes the Print plug-in for the GIMP and Ghostscript and CUPS drivers, as well as Foomatic data.
The package has been renamed in order to clearly distinguish it from the GIMP. While this package started out as the Print plugin for the GIMP, it has expanded into a collection of general purpose printer drivers, and the Print plugin for the GIMP is now only a small (but important) piece of the package. Furthermore, the name Gutenprint recognizes Johannes Gutenberg, the inventor of the movable type printing press. Finally, the word "guten" means "good" in German.
Gutenprint 5.0.0-beta3 is the third beta prerelease of Gutenprint 5.0. It is based on the Gimp-Print 4.3 series that has been in development for over two years, and includes many improvements over the very popular 4.2 series. This release is not considered to be a fully stable release (there are still various things in flux, and it has not undergone the extensive testing that is required to declare a release stable), but we've been using it and we believe that it will be useful for many purposes.
Gutenprint currently contains over 200 drivers supporting in excess of 600 printer models.
The Print plug-in for the GIMP requires the GIMP 1.2.3 or above on the 1.2 line, or the GIMP 2.0 or 2.1. You may need to install packages named "gimp-devel", "gtk-devel", and "glib-devel" (or similar equivalents) on many systems. This plug-in will work with any printing system, and offers a comprehensive user interface to control all aspects of the printing process.
The CUPS driver requires CUPS 1.1.15 or higher. You may need to install a package named "cups-devel" or similar on many systems. Please the rest of the release notes, in particular the Exceptions and Workarounds, for full details on installation, as there is an important caveat. CUPS is the printing system used on Macintosh OS X 10.2 and above, and many other systems use it. The combination of CUPS and Gutenprint provides a flexible, general purpose printing system capable of producing the highest quality output with any of the printers supported by this package. We strongly recommend using CUPS with Gutenprint as a general-purpose printing solution.
The Ghostscript driver requires GNU Ghostscript 6.53 or higher, ESP Ghostscript 7.05 or higher, or AFPL Ghostscript 7.04 or higher. It uses the IJS package included with these versions of Ghostscript to create a driver that may be built much more easily than traditional Ghostscript drivers. The options for this driver are very complex, and it is normally used with the Foomatic driver integration system.
Users of Macintosh OS X 10.2 (Jaguar) and 10.3 (Panther) can use this package, as the printing system is based on CUPS. For ease of installation, a pre-built package with installer is normally supplied a few days after the release of the source package. We highly recommend that OS X users use the pre-built package rather than attempt to build it themselves.
NOTE: This package will not work with any version of OS X 10.0 and 10.1 (such as 10.1.5), as those systems do not use CUPS as their printing system. This is NOT going to be fixed; you must upgrade to at least OS X 10.2 in order to use this package. The reason why is that OS X 10.2 and above use CUPS as the basis of the printing system. OS X 10.0 and 10.1 use a different system that would require a separate driver, and we do not plan to write that driver.
The README file included with this package provides full instructions on building and installing Gutenprint.
These release notes contain the following sections:
1) Changes from 5.0.0-beta2 to 5.0.0-beta3
Please see the `NEWS' file included with the software for information
regarding previous releases.
* Major changes between Gimp-Print 5.0.0 beta 2 and Gutenprint 5.0.0 beta 3:
1) The package has been renamed Gutenprint, and library and header file names have been changed accordingly. All programs using Gutenprint will need to be changed appropriately.
2) The package now compiles on all GIMP 2.x releases, such as 2.0 and 2.2.
3) The GIMP plugin (both 1.2 and 2.x) now offers a copy count option, to permit printing multiple copies of an image as a single operation.
4) The Canon Selphy CP-400 and CP-500 are now supported.
5) Unitone and Hybrid Unitone dithering have been disabled in this release due to some output problems that have been discovered. We recommend use of EvenTone or Hybrid EvenTone dithering instead.
6) Color correction has been tweaked to improve tonality and hue.
7) Shared libraries now build correctly on AIX.
8) The Print plugin for the GIMP now handles unnamed images correctly.
9) Various minor compilation problems have been fixed.
10) The Epson Stylus C65 and C66 has been retuned to improve quality at 720x360 DPI. On these printers, the 720x360 DPI mode produces significantly better output quality than on most other printers.
At present, we do not know whether the C63 and C64 require the same tunings as the C65 and C66. We would appreciate people trying both the C64 and C66 drivers with this printer and reporting to us which driver produces better output.
11) Various minor build problems have been resolved.
