Compiling 2.2.3
Hi all,
In the configuration process, i got this error:
config.status: creating gimp-2.0.pc
config.status: creating gimpthumb-2.0.pc
config.status: creating gimpui-2.0.pc
config.status: creating config.h
config.status: config.h is unchanged
config.status: executing depfiles commands
config.status: executing intltool commands
sed: -e expression #5, char 24: unknown option to `s'
config.status: executing default-1 commands
config.status: executing libgimpbase/gimpversion.h commands
config.status: libgimpbase/gimpversion.h is unchanged
config.status: executing chmod-scripts commands
config.status: executing sed-po-makefiles commands
After that, if i try to compile, it fails, and i think it's because
of the above sed error. I have sed 4.1.2 installed.
Thanks,
