reading directories with ~
reading directories with ~ Gezim Hoxha 13 Nov 22:18
  reading directories with ~ Sven Neumann 14 Nov 00:32
   reading directories with ~ Gezim Hoxha 14 Nov 01:48
   reading directories with ~ Gezim Hoxha 14 Nov 02:25
    reading directories with ~ Sven Neumann 14 Nov 03:22
Gezim Hoxha
2004-11-13 22:18:48 UTC (over 20 years ago)
Hi all.
I'm not sure if this bug has been reported but I just found out what I can't read a directory that starts with a ~ (tilda, the actual name is
"~gezim.hoxha")...I know that I'm supposed to "search" bugzilla and then report this...but frankly I registered an account and it's too complicated...so if anyone wants to file this bug good...if not umm...I'll just change the directory name :D
-Gezim
__________________________________
Do you Yahoo!?
Check out the new Yahoo! Front Page. www.yahoo.com
2004-11-14 00:32:30 UTC (over 20 years ago)
Gezim Hoxha writes:
You could at least mention what version of GIMP you are using.
Gezim Hoxha
2004-11-14 01:48:32 UTC (over 20 years ago)
Sorry I forgot, it was 2.0.4 then I upgraded to 2.0.6 but still it seems unable to open them. At the bottom of the Open Image window it said "Folder unreadable: success"...
-Gezim
Do you Yahoo!?
Gezim Hoxha
2004-11-14 02:25:44 UTC (over 20 years ago)
Actually Sven I'll try and report this on my own, I found some guides on how to report bugs at the bugzilla site ...I'll see how it goes because it's really interesting bug..
--- Sven Neumann wrote:
Gezim Hoxha writes:
just
starts
with a ~ (tilda, the actual name is "~gezim.hoxha")...I know that I'm supposed to
"search"
complicated...so if
umm...I'll
__________________________________ Do you Yahoo!?
2004-11-14 03:22:53 UTC (over 20 years ago)
Gezim Hoxha writes:
Yes, the bug report was well done. Unfortunately it had been reported before (bug #155577) and seems to be caused by the old GTK+ file selection widget which has been deprecated and replaced by GtkFileChooser. The new widget seems to handle those names just fine. This mean there's no such problem in GIMP 2.2 and the GIMP 2.0 tree as well as the GTK+ file selection widget aren't maintained any longer. Thus I had to close your nice bug report as WONTFIX.
