bug in lighting effects filter.
bug in lighting effects filter. Joao S. O. Bueno Calligaris 08 Nov 17:50
bug in lighting effects filter. William Skaggs 08 Nov 22:36
2004-11-08 17:50:32 UTC (over 20 years ago)
Hi..
I did not had a good night, and am filling to sleepy to fill a proper report -
I am just trying to use the "lightning effects" and it seens broken - It seems that when trying to use more than one light source (by setting light "2" to other than None ) the location and direction entries sensitivity b0rks alltogether, disabling things that should be enabled - back on light 1.
Can someone else check it?
Thanks.
JS ->
William Skaggs
2004-11-08 22:36:02 UTC (over 20 years ago)
Joao wrote:
I did not had a good night, and am filling to sleepy to fill a proper report - I am just trying to use the "lightning effects" and it seens broken - It seems that when trying to use more than one light source (by setting light "2" to other than None ) the location and direction entries sensitivity b0rks alltogether, disabling things that should be enabled - back on light 1.
There is definitely a problem -- the sensitivity doesn't update when you change the light type -- although it looks like if you switch to a different light and then switch back, the sensitivity is set correctly the second time. Hmm.
-- Bill
