Dialog layouts in 2.2pre1
Dialog layouts in 2.2pre1 shaneyfelt@juno.com 06 Nov 07:53
Dialog layouts in 2.2pre1 Laxminarayan Ammembal Kamath 07 Nov 08:22
  Dialog layouts in 2.2pre1 Sven Neumann 07 Nov 17:22
Dialog layouts in 2.2pre1 Laxminarayan Ammembal Kamath 08 Nov 13:38
shaneyfelt@juno.com
2004-11-06 07:53:03 UTC (over 20 years ago)
It is a secret conspiracy to kill off the file chooser
I read about that...
http://farbror.acc.umu.se/conspiracy/
_________________
2004-11-07 08:22:29 UTC (over 20 years ago)
 I haven't yet checked out 2.2, i hope i soon will. But any way i have this idea, i think i must post to the gtk team. Yet i am posting it here too, if GIMP can temporarily achieve at implementing this idea. What about a button on the dialog which switches between the "Good old" dialog box and the "New cool" dialog box. It may also have a shortcut key and an option included in the gimp's preferences dialog about which should be default.
Signature: Laxminarayan Kamath Ammembal,
Mithrakoota,
Bhoj Rao's Lane Dongerkery,
Mangalore- 575003
MOBILE : 9845061385
IMMOBILE 0824-2491499
http://www.geocities.com/kamathln
2004-11-07 17:22:11 UTC (over 20 years ago)
"Laxminarayan Ammembal Kamath" writes:
Would you mind to explain what's the "Good old" dialog box and the "New cool" dialog box? If you are talking about the file-chooser then the answer is that it would not be feasible to do this. The APIs of the two widgets differ. It's not a matter of look and feel. It's a completely rewritten widget with a completely different API and lots of different functionality. Also I don't see any advantage in doing what you suggest. It would only introduce inconsistency and bloat.
2004-11-08 13:38:01 UTC (over 20 years ago)
...........If you are talking about the file-chooser then the answer is that it would not be feasible to do this. The APIs of the two widgets differ. It's not a matter of look and feel. It's a completely rewritten widget with a completely different API and lots of different functionality. Also I don't see any advantage in doing what you suggest. It would only introduce inconsistency and bloat. Sven
Then I was right, I must post this enh to gtk team ;)
Mithrakoota,
Mangalore- 575003
MOBILE : 9845061385
