Tiny-Fu 0.9.4: first standalone release
Tiny-Fu 0.9.4: first standalone release Kevin Cozens 12 Oct 01:22
Kevin Cozens
2004-10-12 01:22:13 UTC (over 20 years ago)
Greetings, all.
A tarball of version 0.9.4 of Tiny-Fu is now available at: http://www.interlog.com/~kcozens/software/gimp/tiny-fu.html
This is the first standalone release of Tiny-Fu. In other words, you no longer need to have the full GIMP source tree available in order to build Tiny-Fu. My thanks to Sven Neumann for his work in modifying the 0.9.3 release to use the autoconf tools.
Changes since the 0.9.3 release:
o The build process now makes use of the standard GNU autotools eliminating the need to have the full GIMP source tree available.
o An error message is now generated if the size of an array is different from the previous argument specifying the size (as suggested by Michael Natterer). (Fixes bug #154266)
o Temporarily removed the "Browse" button until the needed code is available via libgimpui (or some other GIMP library).
o The selection-round.scm, and addborder.scm files were updated to the latest versions used in Script-Fu.
o Some minor code cleanup was done and a memory leak was plugged.
