TWAIN debug, crash fix (patch)
TWAIN debug, crash fix (patch) Brion Vibber 07 Oct 05:24
  TWAIN debug, crash fix (patch) Brion Vibber 07 Oct 07:49
Brion Vibber
2004-10-07 05:24:04 UTC (over 20 years ago)
Attached is a patch for the twain plugin which does two things: * fixes crashing and oddness when canceling from the scanning dialog on Mac OS X
* will build the debug version of the plugin on --enable-twain-plugin to configure
I'd very much appreciate it if someone with a Win32 build setup could double-check that this doesn't break anything on Windows, and I would very very much like some feedback from anyone else with a Mac as to whether it works with their scanner.
Currently my entire test base has been the TWAIN SANE bridge driver (which works fine) and the Epson driver for an Epson Perfection 1250 (which mysteriously fails to scan to Gimp). It would be nice to know if it actually works for anyone else... :)
-- brion vibber (brion @ pobox.com)
Brion Vibber
2004-10-07 07:49:59 UTC (over 20 years ago)
That's --enable-twain-debug, naturally.
