Tiny-Fu 0.9.2: second maintenance release
Tiny-Fu 0.9.2: second maintenance release Kevin Cozens 20 Sep 18:24
Kevin Cozens
2004-09-20 18:24:18 UTC (over 20 years ago)
Greetings, all.
A tarball of version 0.9.2 of Tiny-Fu is now available at: http://www.interlog.com/~kcozens/software/gimp/tiny-fu.html
This is the second maintenance release of Tiny-Fu. The most important change is a fix related to the handling of PDB *ARRAY data types. It also allows more data cells to be allocated by the built-in Scheme interpreter. These two changes (plus some other minor changes) means that Tiny-Fu now installs and runs with 92 of the original Script-Fu scripts.
The patch file which hooks the Tiny-Fu source in to the GIMP source tree has been updated to include the directory containing the language translation files as part of a build. I have created files for en_CA and en_GB with all strings translated.
I would appreciate help from anyone who can help with updating the translation files for other languages. I am not expecting any changes to strings used in the program or accompanying scripts in the near future to allow time for the language translation files to be brought up to date.
The next major tasks on the TODO list for Tiny-Fu are to bring some of the documentation up-to-date, and to take a closer look at including full UTF8 support in the embedded Scheme interpreter.
Changes since the 0.9.1release:
o Fixed cons-array definition which fixed the handling of the PDB *ARRAY data types.
o Changed the 'rand' routine for better compatability with the older SIOD version.
o Allow more data cells to be allocated. As a result, 93 scripts are now installed along with the Tiny-Fu plug-in. o Added constant "gimp-dir" for use in scripts. o Updated English language translation files.
