how layers actually get merged?
how layers actually get merged? bear 20 Sep 15:39
  how layers actually get merged? Simon Budig 20 Sep 15:48
how layers actually get merged? William Skaggs 20 Sep 16:29
  how layers actually get merged? Joao S. O. Bueno Calligaris 21 Sep 15:42
how layers actually get merged? bear 20 Sep 16:54
bear
2004-09-20 15:39:15 UTC (over 20 years ago)
hi,
Assume there are four layers, all of which are in Normal mode and grayscale. for a specific pixel in each layer,
Their intensity and alpha values(mapped to [0,1]) are i1,a1
i2,a2
i3,a3
i4(background)
the merged intensity is ((i1*a1+i2*(1-a1))*a2+i3*(1-a2))*a3+i4*(1-a3) am I correct? Thanks!
Simon Budig
2004-09-20 15:48:11 UTC (over 20 years ago)
i2,a2
i3,a3
i4(background)
Yes. You might want to look for the paper T. Porter & T. Duff - Compositing Digital Images for an explantation and the reasoning behind these rules.
The paper itself is available at e.g. http://keithp.com/~keithp/porterduff/
Bye, Simon
William Skaggs
2004-09-20 16:29:44 UTC (over 20 years ago)
i2,a2
i3,a3
i4(background)
I hope not. The proper expression should be
a1*i1 + (1-a1) * (a2*i2 + (1-a2) * (a3*i3 + (1-a3) * i4)).
That is, you have the expression reversed. With your expression, the background could show through even with opaque layers above it.
The best way to think about it is that the projection at layer n is given by the recursive formula
P(n) = a_n * i_n + (1 - a_n) * P(n-1),
where the background is layer 0, and P(0) = i_0.
Best, -- Bill
bear
2004-09-20 16:54:16 UTC (over 20 years ago)
oh, I made a mistake. Thanks a lot!
In your mail:
Reply-To:
To: ,
bear
Subject: Re: [Gimp-developer] how layers actually get merged?
i2,a2
i3,a3
i4(background)
2004-09-21 15:42:18 UTC (over 20 years ago)
On Monday 20 September 2004 11:29, William Skaggs wrote:
Bear wrote:
Assume there are four layers, all of which are in Normal mode and grayscale. for a specific pixel in each layer, Their intensity and alpha values(mapped to [0,1]) are i1,a1
i2,a2
i3,a3
i4(background)
Peering into the code, it is actually simpler than that. The GIMP always treat layers in groups of two, starting at the botton It would do:
new_i3 = i3 * a3 + i4 * (1 - a3)
then:
new_i2 = i2 * a2 + new_i3 * (1 - a2)
and so on. The finalr esult is like above - but it is easier to think on it 2 layers at a time.
Best, -- Bill
