Console window on Win32
40 of 41 messages available
Console window on Win32 Sven Neumann 10 Sep 12:54
Console window on Win32 Sven Neumann 10 Sep 15:30
  Console window on Win32 Tor Lillqvist 11 Sep 08:48
   Console window on Win32 Alif Wahid 11 Sep 12:43
   Console window on Win32 Alif Wahid 11 Sep 13:57
   Console window on Win32 Sven Neumann 12 Sep 13:47
    Console window on Win32 Tor Lillqvist 12 Sep 15:15
     Console window on Win32 John Cupitt 12 Sep 15:14
     Console window on Win32 Sven Neumann 12 Sep 15:16
      Console window on Win32 Nathan Summers 12 Sep 18:52
     Console window on Win32 Nathan Summers 12 Sep 18:47
      Console window on Win32 Nathan Summers 12 Sep 18:58
     Console window on Win32 Jernej Simon?i? 12 Sep 19:19
     Console window on Win32 David Neary 12 Sep 19:36
     Console window on Win32 Alexey Dokuchaev 13 Sep 03:58
     Console window on Win32 Alif Wahid 13 Sep 10:09
    Console window on Win32 Pedro Gimeno Fortea 12 Sep 21:30
     Console window on Win32 Sven Neumann 13 Sep 10:04
      Console window on Win32 Pedro Gimeno Fortea 13 Sep 17:11
       Console window on Win32 Sven Neumann 13 Sep 17:39
        Console window on Win32 Carol Spears 13 Sep 21:55
Console window on Win32 William Skaggs 13 Sep 18:45
  Console window on Win32 Tor Lillqvist 13 Sep 20:09
Console window on Win32 shaneyfelt@juno.com 13 Sep 20:53
  Console window on Win32 Tor Lillqvist 13 Sep 23:26
   Console window on Win32 Jernej Simon?i? 13 Sep 23:43
   Console window on Win32 Daniel K. O. 14 Sep 00:24
   Console window on Win32 Alif Wahid 14 Sep 03:29
   Console window on Win32 Harring Figueiredo 16 Sep 17:24
Console window on Win32 shaneyfelt@juno.com 14 Sep 04:14
  Console window on Win32 Alif Wahid 14 Sep 13:53
Console window on Win32 shaneyfelt@juno.com 14 Sep 20:48
Console window on Win32 shaneyfelt@juno.com 17 Sep 20:59
  Console window on Win32 Nathan Summers 17 Sep 21:47
1095587477.5703.17.camel@sp... 07 Oct 20:23
  Console window on Win32 Tor Lillqvist 19 Sep 12:32
   Console window on Win32 Michael Schumacher 19 Sep 12:56
    Console window on Win32 Tor Lillqvist 19 Sep 13:40
     Console window on Win32 Cai Qian 19 Sep 15:13
      Console window on Win32 Jernej Simon?i? 19 Sep 15:37
       Console window on Win32 Cai Qian 19 Sep 19:49
2004-09-10 12:54:24 UTC (over 20 years ago)
whenever one reads some of the public forums about GIMP there's one problem on the Win32 platform that shows up over and over again:
Whenever GIMP or any library that GIMP is using writes something to stdout/stderr, on Win32 a console window is opened. There is really no reason a user should ever be presented with whatever GIMP or any of it's libraries are sending to stdout/stderr. The console window alone would be annoying and useless enough but the real problem is that closing this window closes GIMP. So what the user sees is an error window with a cryptic message and if you close that window, the application is quit. It is not surprising that the casual user thinks that GIMP has just crashed.
This little stupidity makes GIMP on Win32 look a lot less stable than it actually is. The problem is known for years and gets reported over and over again. Yet noone has ever done anything about it. Why is that? I don't know enough about the Win32 platform but I simply cannot imagine that there isn't a simple solution for this. Why doesn't the Win32 installer setup GIMP in a way that if it is not started from a terminal window, stdout and stderr are redirected to the digital dustbin? There got to be an equivalent to /dev/null on Win32.
2004-09-10 15:30:56 UTC (over 20 years ago)
Alif Wahid writes:
I noticed that GIMP uses message output and debugging functions provided by GLIB. So isn't it possible to fix this by just setting a custom print handler using g_set_print_handler and so on? That would make it portable as well. Just a suggestion anyway. Cheers.
No, it is not possible to fix it this way. Messages sent via GLib are of course not sent to stdout/stderr. At least not by default.
But the GLIB docs for g_set_print_handler say that "Any messages passed to g_print() will be output via the new handler. The default handler simply outputs the message to stdout. By providing your own handler you can redirect the output, to a GTK+ widget or a log file for example". It says the same for g_log functions as well.
Almost all of the messages that cause this problem don't come from the GIMP application. They are created by libraries that we are using and these libaries aren't necessarily using g_print() and g_printerr().
Also I don't see why we should be redirecting stdout and stderr. Everything that shows up there is strictly just for the eyes of developers. We use g_message() for all messages that are meant to be seen by users. Such messages then are processed by the following logic:
If GIMP was started with the --console-messages command-line option, the messages go the console (stdout iirc). Otherwise they are shown in the Error Console dockable. If that dockable doesn't exist, an error dialog pops up. If for whatever this isn't being successful (I can't think of reason), the message ends up on the console.
So since stdout/stderr are not for the user's eyes, why are the poor GIMP users on the Win32 platform faced with it?
Tor Lillqvist
2004-09-11 08:48:28 UTC (over 20 years ago)
Sven Neumann writes:
> Almost all of the messages that cause this problem don't come from the > GIMP application. They are created by libraries that we are using and > these libaries aren't necessarily using g_print() and g_printerr().
Nope, you have it backwards. 3rd-party libraries who write to stdout directly don't cause them.
> Also I don't see why we should be redirecting stdout and stderr. > Everything that shows up there is strictly just for the eyes of > developers.
Some clarification here: The GIMP executable is linked as a "GUI" application. This means that it doesn't have any console window when it starts. stdout and stderr are not connected to anything. Writing to them doesn't go anywhere, and certainly doesn't open a console window for the application.
It's the g_print() etc functions that explicitly open a new console window if stdout (or stderr) isn't connected to a valid file handle.
It would be possible to make it impossible to close the console window that GLib opens, by removing the close button from it. Then users would know just to minimize it if they aren't interested in the messages. See my last comment in bug #141102.
> We use g_message() for all messages that are meant to be > seen by users. Such messages then are processed by the following logic: >
> If GIMP was started with the --console-messages command-line > option, the messages go the console (stdout iirc).
Hmm, if most GIMP users on X11 start GIMP through some window manager whose stdout isn't visible, is that option then really supposed to mean "don't show messages"?
I guess there is a mismatch in the ways of thinking here: GIMP thinks that writing to stdout means the output will mostly go somewhere where the user doens't see it, unless he explicitly does something unusual (starts GIMP from the command line).
The Win32 code in GLib again thinks that g_print() etc messages are *important*, and supposed to be shown to the user in some way, even opening a new console window if there isn't one already. If the user wants to redirect stdout and stderr (to NUL: or a file), he can do it from the command line.
--tml
Alif Wahid
2004-09-11 12:43:43 UTC (over 20 years ago)
It's often a habitual thing for windows users, minimizing a console window that displays constant warning messages often isn't enough satisfaction for some. May be GIMP could have a preference option where the user can choose to have these g_print based messages redirected to a file using a custom print handler that gets set via g_set_print_handler(..).
Alif.
Alif Wahid
2004-09-11 13:57:14 UTC (over 20 years ago)
Hi Tor,
I've played around with the g_set_print_handler and the g_log_set_handler functions and they certainly stop the console window from coming up when I use my custom handler to redirect the message to somewhere else. So it may well be a good way to give the user an option of redirecting these stdout and/or stderr messages to somewhere totally invisible.
Alif.
--tml
2004-09-12 13:47:14 UTC (over 20 years ago)
Tor Lillqvist writes:
There got to be a way to change this behaviour of g_print(), no?
John Cupitt
2004-09-12 15:14:24 UTC (over 20 years ago)
On Sun, 12 Sep 2004 13:15:37 +0000, Tor Lillqvist wrote:
Could we have a raise-of-hands here? Who thinks GLib shouldn't bother doing that console window allocation stuff at all?
It's handy during development, but annoying for a released app. I'm about to hack something into my app to suppress it (almost all my users get a bunch of harmless but irritating font warnings on startup and then moan on my mailing list).
How about having no console window by default, and add a g_win32_console_whatever() thing which apps could set as a print handler with an #ifdef DEBUG
Tor Lillqvist
2004-09-12 15:15:37 UTC (over 20 years ago)
gtk-app-devel-list people, check the start of this thread from the gimp-developer archives at
http://www.mail-archive.com/gimp-developer%40lists.xcf.berkeley.edu/msg07988.html
Sven Neumann writes: > There got to be a way to change this behaviour of g_print(), no?
Well, one could redirect stdout and stderr to /dev/null (i.e. NUL: on Windows), either in the command line that starts GIMP, or even in GIMP itself with freopen(). If stdout or stderr are connected to NUL:, they aren't invalid, and g_log() won't open any console window.
One could even go so far that if there is a consensus among GTK+ app developers (whose apps run on Win32) that the opening of console windows in GLib was a silly idea and has been of little use, that code could just be removed. g_print() etc would then write to stdout or stderr, like on Unix, regardless of whether they are connected to anything or not. It would then be the end user's responsibility to redirect stdout/stderr of a GUI application to a file if they want to see whatever might be written to stdout/stderr.
Personally I don't have any preference.
--tml
2004-09-12 15:16:21 UTC (over 20 years ago)
+1
Nathan Summers
2004-09-12 18:47:44 UTC (over 20 years ago)
I too think it's more trouble than it's worth. If nothing else, it's different from how stdout is treated on X (and I assume other ports as well). Since a lot of Windows GTK stuff is just ported over from X, it's likely that the developers don't even know that they are spamming the Windows users.
Rockwalrus
Nathan Summers
2004-09-12 18:52:05 UTC (over 20 years ago)
+1
Nathan Summers
2004-09-12 18:58:02 UTC (over 20 years ago)
Replying to your own message is a sign of insanity. Guilty as charged. :)
On the other hand, if it were just factored off into a separate function, and suitable implementations were provided for the other ports, I could see this as a useful optional g_log handler that a GTK app could choose to install.
Rockwalrus
Jernej Simon?i?
2004-09-12 19:19:48 UTC (over 20 years ago)
How about setting an environment variable? If something like OPEN_CONSOLE is set, open the console window when needed, otherwise not?
Anyway, I'm in favour of not opening the console by default. It's easy enough to change a GUI program to open console on startup, if that's needed.
David Neary
2004-09-12 19:36:53 UTC (over 20 years ago)
Me too.
I hate threads that degenerate into this, but it's the most annoying thing possible in a GUI app :)
Cheers, Dave.
Pedro Gimeno Fortea
2004-09-12 21:30:30 UTC (over 20 years ago)
Regardless on what's done in the glib side, why not using g_set_print_handler and g_log_set_handler, as Alif Wahid suggests, to redirect the messages to the Error Console? I, for one, as a user of the Win32 version expected to find the messages there and when they were shown in a different window I wondered why. Perhaps it's also better under Linux so that the messages aren't lost if the user doesn't open gimp from a console.
Alexey Dokuchaev
2004-09-13 03:58:36 UTC (over 20 years ago)
Me. :)
./danfe
2004-09-13 10:04:06 UTC (over 20 years ago)
Pedro Gimeno Fortea writes:
The messages aren't meant for user's eyes, I think I mentioned that. The messages don't make any sense for the user and should only ever seen by developers or when we ask users to start gimp from a console window and to tell us if there are messages to be seen.
If you think that a certain messages should be seen by the user and not to go stderr, let us know about it. That message should then use g_message() and also needs to be localized.
Alif Wahid
2004-09-13 10:09:03 UTC (over 20 years ago)
Hi Tor,
I support this idea, that GLIB shouldn't bother opening a console window at all. Cheers.
Alif.
Pedro Gimeno Fortea
2004-09-13 17:11:28 UTC (over 20 years ago)
Doesn't it make sense to prefix Glib errors with something like: "Glib Error:" or "System Error:" or "Gimp Error:" (localizing just that string) and let the rest appear as-is within the error console?
No, that's not exactly the case. But using stderr is a bad idea under Windows for the reasons that motivated this thread.
2004-09-13 17:39:00 UTC (over 20 years ago)
No. The user is not supposed to see them, never. Actually no such messages should ever be emitted. If it does, there's a programming error. It would not help to show these messages to the user.
William Skaggs
2004-09-13 18:45:31 UTC (over 20 years ago)
What about a user who wants to file a bug report? Surely they are relevant in that case?
Best, -- Bill
Tor Lillqvist
2004-09-13 20:09:26 UTC (over 20 years ago)
William Skaggs writes:
> What about a user who wants to file a bug report? Surely > they are relevant in that case?
They can then start the GUI app with explicit redirection of stdout and stderr to a file.
--tml
shaneyfelt@juno.com
2004-09-13 20:53:34 UTC (over 20 years ago)
]> Doesn't it make sense to prefix Glib errors ]with something like: "Glib
]> Error:" or "System Error:" or "Gimp Error:" ](localizing just that
]> string) and let the rest appear as-is within ] the error console?
]No. The user is not supposed to see them, never. Actually no such ]messages should ever be emitted. If it does, there's a programming ]error. It would not help to show these messages to the user.
They are useful for bug reports.
I would like to see a clean way to control logging of various messages. The messages would ideally be able to be shown in a real window (not the console), tee to a file, etc. by checking logging options in the user preferences.
The log window (not the console window) should pop up when the first log entry occurs. GTK+ System level logging could be disabled initially, with a checkbox to enable it. Saving the log to a file could also be initially disabled. When scripts running autonomously in non-GUI mode, use stderr or logfile for error messages instead.
Just my opinion.
_-Ted
p.s. But if it's going to hold up the release, stub out the code in this release to do something simpler.
_________________
Carol Spears
2004-09-13 21:55:46 UTC (over 20 years ago)
spew is beautiful though.
i would rather users get over it and even read it.
you guys forget that as soon as the shock of the new thing is over, spew is really really interesting.
Tor Lillqvist
2004-09-13 23:26:52 UTC (over 20 years ago)
shaneyfelt@juno.com writes:
> The messages would ideally be able to be shown in a real window > (not the console)
And what's so unreal about a console window? Is is just that they are black and white and make (some) people think of MS-DOS? (Some call console windows "DOS boxes" and seem to think "A-ha! a DOS box! So GIMP really runs on DOS!" ;-)
> The log window (not the console window) should pop up when the first > log entry occurs.
Please tell me in what way such a "log window" would look and behave differently from a console window? For all intents and purposes, that's what they are supposed to be. Is it just the colours?
(Remember that we are talking about facilities in GLib here. GLib has no GUI. GIMP's "error console" is somehing else.)
> GTK+ System level logging could be disabled initially, with a > checkbox to enable it.
Well, it's GLib that opens a console window if stdout or stderr aren't connected to anything (not even the bit bucket) when g_print(), g_message(), g_warning(), g_error(), g_printerr() etc are called. Where would such a checkbox be? These calls are done for instance by the Pango library, it doesn't have any GUI of its own either.
The consensus so far seem to be that GLib should not open any console windows by itself. OK, fine with me, such a change could be done even in the stable branch (2.4.x) IMHO. But I certainly hope that it doesn't mean that people then will start whining that they want "log windows" for warnings and error messages. Sheesh, that's what the console windows are/were, dammit.
--tml
Jernej Simon?i?
2004-09-13 23:43:10 UTC (over 20 years ago)
If anybody wants log windows back, it's easy to change the compilation process to produce a console EXE - or, if the user doesn't have (or doesn't want to use) a compiler, there are programs that can switch an already compiled EXE file between console/GUI applications (it's a matter of changing 1 byte).
Daniel K. O.
2004-09-14 00:24:15 UTC (over 20 years ago)
I vote for:
* g_print(): popup a console window; if the programmer is using g_print(), he probably wants to see something. * g_warning(): use OutputDebugString, so the only people who can do something about the warnings can use something like DebugView (from Sysinternals) to see it.
* any other function just use (f)printf.
Daniel K. O.
Alif Wahid
2004-09-14 03:29:44 UTC (over 20 years ago)
Hi Tor,
Like Jernej mentioned, if anybody wants to have a console window then they just have to compile it without the -mwindows option in GCC and whatever equivalent in MSVC. I think if a developer explicitly compiles a program to be GUI only on win32, then he/she expects to see no console window. So in my humble opinion, I think GLIB should not open a console window if stdout and stderr doesn't exist. I also do not think that a "log window" is necessary since the console window can be so easily obtained.
Developers also have the option of using g_log_set_handler and g_set_print_handler functions for hooking into any messages generated and redirecting them to somewhere else (file, application dialogs etc.).
Perhaps, it would be nice if somehow the console window opened currently could be closed without shutting down the whole GUI application. Unfortunately, windows does not allow that I think. Or does it?
Alif.
shaneyfelt@juno.com
2004-09-14 04:14:48 UTC (over 20 years ago)
Here's what a log window would look like:
A log window would have a button that says "Clear" to clear the log and one that says "Close" to close the window, and maybe something that says what file to tee. Nothing should shutdown the GUI unless clearly marked and accompanied by a clear confirmation that says on the button "QUIT AND DISCARD CHANGES" or similar text.
This log window would be nice, but it's probably not worth all the fuss - for this release, at least.
The important thing is to not allow a Windows console to come up and kill the application like it does.
_-Ted
_________________
Alif Wahid
2004-09-14 13:53:11 UTC (over 20 years ago)
It doesn't make sense to have such log windows as a part of GLIB. Sounds like this sort of log window could really come in handy as part of GTK perhaps?
I think somehow the console window can be made closeable but when closed, doesn't shut down the whole app, then that would be ideal solution. Anyone know if it is possible to close some sort of a console window and still keep other proper GUI windows open so the app doesn't exit?
Alif.
_-Ted
________________________________________________________________ Get your name as your email address. Includes spam protection, 1GB storage, no ads and more Only $1.99/ month - visit http://www.mysite.com/name today! _______________________________________________ Gimp-developer mailing list
Gimp-developer@lists.xcf.berkeley.edu http://lists.xcf.berkeley.edu/mailman/listinfo/gimp-developer
shaneyfelt@juno.com
2004-09-14 20:48:53 UTC (over 20 years ago)
See KB article 818361 concerning disabling the close button on the title bar. This seems to be the important part:
hWnd = ObtainWindowHandle(name); hMenu = GetSystemMenu(hWnd, false);
DeleteMenu(hMenu, 6, 1024);
I haven't tried it. You probably have the window handle and don't need the first line. Just guessing.
_-Ted
_________________
Harring Figueiredo
2004-09-16 17:24:18 UTC (over 20 years ago)
--tml
This is EXACTLY what will happen -- People will say: "Stupid glib is dumping core -- (or should I say "crashing" since we are talking about windows?) and I have no clue where in MY program I am messing up --
Leave the DOS-Window, console window, DOS box alone !!!
What is the trade off -- Have a "DOS box" or find potential problems faster ?
PS - If the user is scared of the "DOS box" -- Why wouldn't she be scared of a log window as well ?
HF.
Do you Yahoo!?
New and Improved Yahoo! Mail - Send 10MB messages!
http://promotions.yahoo.com/new_mail
shaneyfelt@juno.com
2004-09-17 20:59:38 UTC (over 20 years ago)
Harring,
The serious problem is not that the dos console looks scary, although it is ugly, that would be ok for ms windows. The problem is that windows hangs any application with a console window if someone happens to click on the text in the box, for example, to copy it, or by accidentally touching it with a stylus. This is the serious problem, not some sort of confusion over what a console window is.
Actually what is happening is the application gets suspended at the next console output until the selected area on the console is unselected. Obviously, if ms windows were any good, it would queue the output rather than suspending the GUI application, but the typical user can't distinguish this problem from a crashed GIMP. However, it is in our power to work around the problem. One such workaround is to only use a console if a command line option (like --console) or an environment variable is set.
Ted
_________________
Nathan Summers
2004-09-17 21:47:45 UTC (over 20 years ago)
Since gtk already meddles with the program's arguments, it's not unreasonable for this to be done at the gtk level.
Rockwalrus
Tor Lillqvist
2004-09-19 12:32:45 UTC (over 20 years ago)
I wrote:
> > Except that on Windows it's not "or", but "and". Just starting a GUI > > application from a command shell in a console window doesn't make its > > stderr and stdout connected.
Iago Rubio writes: > True, but I think my point of view is still valid. No Windoze app opens > a console for output.
Yes. My point was mostly directed to Unix-oriented people to warn them not to think or advice Windows users that "just start the application from a command prompt and you will see the output". It isn't that easy.
For instance to see the help text from "gimp --help" on Windows one has to pipe its output to more. (Currently, with the console-window-opening still in GLib, the text output appears in a console window that opens but that then immediately closes when GIMP terminates...)
Unfortunately there doesn't seem to be any way for a Windows application to check whether it has actually been started from a command interpreter in a console window, and not Explorer (so that it might in that case attach its stdout and stderr to that console window). Or is there? I can't even find any API to find out the parent process of a process...?
--tml
2004-09-19 12:56:24 UTC (over 20 years ago)
When started from the MinGW (and probably Cygwin) bash, this doesn't happen. The output appears in the same console (rxvt window). Of course, it isn't really running on Windows in this case, but at least developers using thiese environments shouldn't be affected by the lack of the output then (or will they?).
Tor Lillqvist
2004-09-19 13:40:50 UTC (over 20 years ago)
Michael Schumacher writes:
> When started from the MinGW (and probably Cygwin) bash, this doesn't > happen. The output appears in the same console (rxvt window).
Wow. Didn't know that. I seldom use MSYS and its rxvt. I assume rxvt's window isn't a console window, it's a normal "graphics" window that just happens to contain only text, handled by the rxvt application itself. (I.e. it's like xterm etc on X11. A Unix equivalent of console windows would be built-in text-only windows in the X server, or something.)
Rxvt itself presumably passes some pipes for stdout/stderr to applications it starts and then shows whatever comes through those pipes.
Few end-users have rxvt, though.
--tml
Cai Qian
2004-09-19 15:13:31 UTC (over 20 years ago)
huh, that is wrong, many people in Asia really perfer it, coz its nice wide-width characters handling.
Regards, Cai Qian
Jernej Simon?i?
2004-09-19 15:37:35 UTC (over 20 years ago)
Does that include Windows users?
Cai Qian
2004-09-19 19:49:01 UTC (over 20 years ago)
No, only those Cygwin people.
