[miguel@ximian.com: Re: introductions]
[miguel@ximian.com: Re: introductions] Carol Spears 05 Sep 04:25
  FIle Selector- was Re: [miguel@ximian.com: Re: introductions] Joao S. O. Bueno Calligaris 05 Sep 05:53
  [miguel@ximian.com: Re: introductions] Sven Neumann 05 Sep 10:17
   [miguel@ximian.com: Re: introductions] Carol Spears 05 Sep 10:36
Carol Spears
2004-09-05 04:25:14 UTC (over 20 years ago)
hi,
anyone want to handle this accusation from miguel? he says that the new file selector is the responsibility of the gimp developers.
----- Forwarded message from Miguel de Icaza -----
Envelope-to: carol@gimp.org Subject: Re: introductions
To: Carol Spears
Hello Carol,
You should complaint to the GIMP people for using the new file selector. The old file selector is still available in Gtk+, and it is them who have chosen to use a different file selector.
Maybe they are also conspiring against you, you are probably too annoying.
Miguel
----- End forwarded message -----
2004-09-05 05:53:42 UTC (over 20 years ago)
It did not appear to me as an accusation at all. A bit curde, one could say, but as it is, it is out of context.
On the other hand, maybe reverting to a file selector were no secret CTRL+L is needed __should__ be indeed considered. Somw work toward customizing it maybe would do no harm. But I have to agree, I find the new file selector of little use.
JS ->
On Saturday 04 September 2004 23:25, Carol Spears wrote:
hi,
To: Carol Spears
Hello Carol,
Miguel
----- End forwarded message ----- _______________________________________________ Gimp-developer mailing list
Gimp-developer@lists.xcf.berkeley.edu http://lists.xcf.berkeley.edu/mailman/listinfo/gimp-developer
2004-09-05 10:17:29 UTC (over 20 years ago)
Carol Spears writes:
Sure, no problem.
To: Carol Spears
Hello Carol,
Miguel is correct when he says that we have choosen to use the new file chooser. We think that it is an improvement over the old GtkFileSelection widget which has caused a lot of grief. The new widget however has still room for some vital improvements and it is our responsibility to try to implement these improvements together with the GTK+ developers and GNOME usability folks.
Miguel has got a point here. Not about the conspirancy though.
Carol Spears
2004-09-05 10:36:08 UTC (over 20 years ago)
Sure, no problem.
To: Carol Spears
Hello Carol,
luis told me the changes were made for his mother.
someone should clear this up. apologize for either making these changes or for telling me this at guadec.
