preparing GIMP 2.2 (fwd)
Forwarding to the list in case others are interested
relevant to bug report
http://bugzilla.gnome.org/show_bug.cgi?id=145145
plan: moving patterns from Toolbox to the current image
---------- Forwarded message ----------
Date: Mon, 9 Aug 2004 18:52:24 +0100 (BST)
To: Sven Neumann
Subject: Re: [Gimp-developer] preparing GIMP 2.2
Status on my pattern changes, in case you are wondering
This list doesn't include tasks that have already been started but
I have most of the patterns done. Now most of them also work off the
current selection if there is one.
Problems. I started this work based on Gimp 1.2.x scripts (I presumed the
changes would minor and would likely be rejected so I did what was best
for my own purposes at the time) and as a result I have had difficulties
forward porting Truchoid. I could probably redo my changes staring
againts the 2.0 version but it will be a real pain and this will likely
delay me significantly.
I have also rewritten Swirly to be between 3-4 orders of magnitude faster.
I made it work off the current image too but it adds a new layer
containing a square to the current image and I have not sorted out tiling
it to the current image yet.
I'll try and get more done this week, with any luck I'll get my head
around Swirly and only have Truchoid left to do. Either way I'll post
most or all of what I have on my site later in the week and file
additional bug reports for the ones that are finshed.
I have spent a lot of time but I have other work I really should be doing
and I am not confident I'll be able to spare enough time to get them all
done in time for 2.2 but I'd be very dissapointed to have my work left
out.
- Alan
