Adaptive Contrast Enhancement
Then I began to port it and release 0.6.44 that is not fully clean and some
points have not been ported yet. So if you have time and enogh knowledge it
would help a lot.
I have modified the plug-in to compile against GIMP 2.0. You can start it
already (Image -> Colors -> Adaptive Contrast, should maybe be moved to
"Layer->Colors"), but it is not fully functional (for example, OK/Cancel
buttons do not work, but the preview does). The changes I made are mostly
autotools-related (mainly configure.in). I also removed the "intl" program
from the distribution. I did not modify any internals, in case you want to
restructure the plug-in further.
You can download the intermediate 0.6.45 version from:
http://stud4.tuwien.ac.at/~e0225855/gimp-ace-0.6.45.tar.gz
What still needs to be done: The dialog handling (dialog.c) is deprecated. I
marked the few lines I had to change to make the plug-in compile with
"TODO" (2 occurrences in dialog.c). You would now use "gimp_dialog_run" to
present the dialog (take for example "gimp-2.0.2/plug-ins/common/mblur.c" to
see how it should be done) and check for GTK_RESPONSE_OK.
gimp_ace.c: gimp_plugin_help_register has changed. I don't know what you want
to do with the call (make a web-page for the project etc.), or what you
should point to (e.g., on-disk HTML documentation). It is commented out for
now and also marked with "TODO". (There is also another occurrence of "TODO",
namely in glaceG.c, but I did not add that, so apart from this, grepping for
"TODO" should lead directly to the relevant places.)
I think you now have a pretty solid basis to work on (because the necessary
infrastructure is there), but please feel free to e-mail me in case you need
further assistance with enhancing the plug-in. Good luck.
Markus.
