[PATCH] Gimpressionist Revamp (revision 21)
[PATCH] Gimpressionist Revamp (revision 21) Shlomi Fish 28 Jun 10:59
Shlomi Fish
2004-06-28 10:59:10 UTC (almost 21 years ago)
Hi all!
Well, continuing with my work on creating a usable PDB function for gimpressionist:
http://bugzilla.gnome.org/show_bug.cgi?id=144913
I decided to heavily revamp the code, as I've seen it leaves a lot to be desired. Attached is the latest version of the patch. Note that my work is by no means finished.
This patch includes the modification done in the gimpressionist PDB modifications, just as a convenience for me. Nevertheless, I would recommend applying the PDB stuff to the CVS beforehand, and then I'll create a new patch against CVS Head.
Changes I made include:
1. Moved all the non-static globals to one module.
2. Created functions out of duplicate code.
3. Eliminated function parameters that are always the same. (and accessed the relevant globals instead).
4. Replaced commented-out code with #if 0 ... #endif blocks.
5. Eliminated some memory leaks.
6. Created a new module - utils.c - with utility functions that as a general rule don't modify the state of the program.
The other past and future versions of the patch can be found here:
http://shlomif.il.eu.org/gimp/gimpressionist/
Or if you have DNS resolution problems:
http://vipe.technion.ac.il/~shlomif/gimp/gimpressionist/
Shlomi Fish
