Blur plug-in
14 of 14 messages available
Blur plug-in Sven Neumann 07 Jun 11:49
  Blur plug-in Dave Neary 07 Jun 14:16
  Blur plug-in GSR - FR 07 Jun 15:10
   Blur plug-in Sven Neumann 07 Jun 16:49
    Blur plug-in GSR - FR 07 Jun 17:22
     Blur plug-in geert jordaens 07 Jun 17:59
      Blur plug-in GSR - FR 07 Jun 18:37
       Blur plug-in Sven Neumann 07 Jun 20:22
        Blur plug-in Nathan Carl Summers 08 Jun 23:50
   Blur plug-in Alan Horkan 08 Jun 18:31
  Blur plug-in Christopher Curtis 08 Jun 00:50
Blur plug-in William Skaggs 07 Jun 20:04
  Blur plug-in Daniel Egger 12 Jun 14:12
Blur plug-in William Skaggs 08 Jun 01:12
2004-06-07 11:49:52 UTC (over 21 years ago)
Blur plug-in
I'd like to get some feedback on the following plan for the Blur plug-in
(details are in http://bugzilla.gnome.org/show_bug.cgi?id=142318):
The plan is to remove the randomize and repeat functionality. That would allow us to also remove the (quite confusing) dialog. Filters->Blur->Blur would then be a simple blur with a 3x3 convolution kernel. It would be fast and easy to use but of course we it would be less powerful. So the question is, is anyone actually using this functionality? Are there scripts out there that rely on plug-in-blur-randomize to be available?
Dave Neary
2004-06-07 14:16:19 UTC (over 21 years ago)
Blur plug-in
Sounds OK to me.
Cheers,
Dave.
GSR - FR
2004-06-07 15:10:30 UTC (over 21 years ago)
Blur plug-in
sven@gimp.org (2004-06-07 at 1149.52 +0200):
Why not just ditch it completly then? If it just a 3x3 convolution that you have to manually repeat, and there are already other filters and scripts that do the same. The point of repeat is not having to rerun manually to get a "bigger radius" blur.
Someone was doing a version that used another channel to control the repeats, which is a nice improvement. If that is accepted as improvement it should stay, otherwise I see no reason to keep it along the generic matrix one and its presets.
GSR
2004-06-07 16:49:35 UTC (over 21 years ago)
Blur plug-in
GSR - FR writes:
Sorry, but what other scripts or plug-ins are you referring to? IMO it would be a good thing to have a simple and fast plug-in that does the job w/o a dialog and I fail to see what other plug-in would provide this functionality.
GSR - FR
2004-06-07 17:22:52 UTC (over 21 years ago)
Blur plug-in
sven@gimp.org (2004-06-07 at 1649.35 +0200):
Convolution matrix, and there are scripts floating around that give matrix presets.
GSR
geert jordaens
2004-06-07 17:59:17 UTC (over 21 years ago)
Blur plug-in
GSR
calling the convolution matrix plug in and scripts to preset it a simple replacement ?
Please rephrase that to a powerful replacement that can be used by the more then average(new) gimp user.
Would this mean having a script-fu menu entry fill convolution matrix for : blur/sharpen/edge detect etc.
1. simple and fast blur operation as it is known in other graphical programs will help new gimp users to get arround. 2. when using the randomize option the preview makes no "real" sense since by nature you'll never get twice the same result. 3.Instead of executing the blur option multiple times one could use a bigger kernel (5x5, 7x7) as often used. This would suggest a dialog box. 4. If a bigger blur is needed use the gausian blur instead of repeating. 5.Writing a script to repeat the plugin multiple times would be a better option then calling a script to fill the convolution matrix. at least the script could be used to repeat all plug-ins. Or why not add a menu option repeat last plugin n times.
Geert
GSR - FR
2004-06-07 18:37:17 UTC (over 21 years ago)
Blur plug-in
geert.jordaens@pandora.be (2004-06-07 at 1759.17 +0200):
Well, what would you call a script that just puts a menu entry and calls convolution matrix with a fixed matrix?
Those already exists. The ones I got have some extra controls, but nothing disallows making no dialog versions.
Depends how the code is done, using pseudo random and taking into account 2d coord it should provide repeatable results.
They are different things, though, box vs guassian.
GSR
William Skaggs
2004-06-07 20:04:17 UTC (over 21 years ago)
Blur plug-in
The main reason not to use convmatrix is that internally it always does a 5x5 convolution, regardless of the matrix entries. This means it should take almost three times as long as the 3x3 convolution in blur.c; in fact, a little testing on a 5000 x 10000 image shows it taking over four times as long. Otherwise using convmatrix would probably be the right solution.
Best, -- Bill
2004-06-07 20:22:17 UTC (over 21 years ago)
Blur plug-in
GSR - FR writes:
I'd call it a waste of resources. Actually such a simple task as applying a convolution kernel should probably be done completely in the core.
Christopher Curtis
2004-06-08 00:50:47 UTC (over 21 years ago)
Blur plug-in
Is it possible to remove the dialog without removing the options?
Also, I skimmed the bug report, which was initially about a preview. Another random thought (based on my previous 'impossible' one: Does it seem possible to make a 'fixed' preview area somewhere (maybe in the layers dialog?) that all plugins have access to, instead of reimplementing each one? Then maybe have this preview area call into the plugin to update itself when the user interacts with it?
I realize this may not be a practical thing, but it may be something that someone else could run with ...
Chris
William Skaggs
2004-06-08 01:12:59 UTC (over 21 years ago)
Blur plug-in
Yes, it is possible, that's why Sven asked the question. The options don't have any obvious utility, though (repeat blurring is nothing more than a very slow way of producing a Gaussian blur), so there does not seem to be any good reason for keeping the options unless deleting them will break something that already exists.
This could be done with some cleverness, but I would oppose it on the grounds that the preview should be as near as possible to the controls.
Best,
-- Bill
Alan Horkan
2004-06-08 18:31:27 UTC (over 21 years ago)
Blur plug-in
On Mon, 7 Jun 2004, GSR - FR wrote:
Date: Mon, 7 Jun 2004 15:10:30 +0200 From: GSR - FR
To: gimp-developer@lists.xcf.berkeley.edu, gimp-user@lists.xcf.berkeley.edu Subject: [Gimp-user] Re: Blur plug-in
If there was a more convenient way to save a 3x3 convolution matrix than having to write a script-fu script around the convulotion matrix plugin then there would not be any reason to keep the blur plugin but at the moment manually typing in a convulation matrix gets really annoying really fast.
- Alan
Nathan Carl Summers
2004-06-08 23:50:37 UTC (over 21 years ago)
Blur plug-in
*chuckles* I agree.
Rockwalrus@aol.com
Daniel Egger
2004-06-12 14:12:21 UTC (over 21 years ago)
Blur plug-in
I agree with Sven here that convolution should be done by the core (probably even support SIMD, where available) and be usable for all plugins and integrated tools. IMHO it would also make sense to offer special functions which allow for 3x3, 4x4, 5x5 and maybe also generic sizes of matrices for optimum speed and cache utilization.
Servus, Daniel
