Color Space in Gimp
Color Space in Gimp Bartekk 18 May 20:22
  Color Space in Gimp Peter Kirchgessner 30 May 07:51
Bartekk
2004-05-18 20:22:56 UTC (almost 21 years ago)
Color Space in Gimp
I have some Pictures in a color space with only R and G values. But if I want to use some Plugins it doesn't work because they use the gray color space or rgb or another.
Now i don't know which color space i have to use if i want to build my own plug in. If I use the rgb and convert my image to this color space i need more time to use this plug in , because of more values.
Is there a possibility to managed it with another color space or define a own color space and used it in gimp.
maybe is there somebody with an idea.
thanks
bartekk
Peter Kirchgessner
2004-05-30 07:51:36 UTC (almost 21 years ago)
Color Space in Gimp
many plug-ins are working on the R, G, and B-values independantly. So you can try to use these plug-ins. After that you only have to extract the R- and G-values from the resulting image.
Kind regards
Peter
thanks
bartekk
Gimp-developer@lists.xcf.berkeley.edu http://lists.xcf.berkeley.edu/mailman/listinfo/gimp-developer
