Gimp on Slashdot
1 of 2 messages available
S28596AbUEGL7D/200405071159... 07 Oct 20:22
  Gimp on Slashdot Simon Budig 07 May 15:06
Simon Budig
2004-05-07 15:06:15 UTC (almost 21 years ago)
Gimp on Slashdot
Juhana Sadeharju (kouhia@nic.funet.fi) wrote:
But maybe they are not that easy to code? Adding a vector layer to the images should be easy if the image object is good, but the vector manipulations can be difficult. Typically each plugin has its own kludge way to manipulate vector objects (selection tools, crop tool, etc). The selection tool vector drawing and the crop tool vector drawing are not visible in other views of the same image because the framework is kludge.
What we need is a good old vertex/edge/polygon framework. We don't have even the simplest systems developed at 1960s. Check out ftp://ftp.funet.fi/pub/sci/audio/devel/constraints/sketchpad.pdf what I mean.
The Link you gave does not work.
I'm figuring out what kind of framework would be ok. Anyone would like to help?
Why isn't this discussed on gimp-devel?
In fact there is a vector based infrastructure and I also believe that it is quite flexible. Simply fiddle a bit with the Path tool to get an idea how this works.
Yes, it is not integrated in all the places where it should be, but it definitely is there and it definitely is quite flexible (although I am biased about that).
Maybe you should look at the code before drawing conclusions like "the framework is kludge". I've put quite a lot of work into that stuff and I'd like to see at least some reasons *why* it supposedly is a cludge.
Bye, Simon
