Plug-in howto
10 of 10 messages available
Plug-in howto Bartekk 03 May 02:18
  Plug-in howto Dave Neary 03 May 10:19
   Plug-in howto Sven Neumann 03 May 12:48
    Plug-in howto Dave Neary 03 May 13:13
     Plug-in howto Sven Neumann 03 May 13:22
      Plug-in howto Dave Neary 03 May 13:41
      Plug-in howto Nathan Carl Summers 03 May 22:43
       Plug-in howto David Neary 03 May 22:55
  Plug-in howto Sven Neumann 03 May 12:47
   Plug-in howto Bartekk 04 May 16:26
Bartekk
2004-05-03 02:18:59 UTC (almost 21 years ago)
Plug-in howto
i have a question about the development of plug-in. I want to use the plugin template u can get from the gimp site. The problem is I don't know which files are important. If I want to write a simple Gaussian Filter, how can I do that.
Is there somebody who can give me an how to or an example.
Thanks a lot.
bartekk
Dave Neary
2004-05-03 10:19:23 UTC (almost 21 years ago)
Plug-in howto
Hi Bartekk,
This document is still somewhat valid, although the API has changed a lot since then, the principles are the same (the API changes are fairly evident in the plug-in template):
http://gimp-plug-ins.sourceforge.net/doc/Writing/html/plug-in.html
You might want to look at the Gaussian blur plug-in, the edge detect plug-in and the generic convolution filtre plug-in in (respectively) plug-ins/common/gauss_rle.c, plug-ins/common/edge.c and plug-ins/common/convolve.c - all of these plug-ins are of the type which interests you.
Cheers,
Dave.
2004-05-03 12:47:10 UTC (almost 21 years ago)
Plug-in howto
"Bartekk" writes:
For such a simple plug-in you will probably want to keep all code in one file and the plug-in template is complete overkill. You can simply use gimptool to build your plug-in and probably don't need a full-featured autoconf/automake setup as provided by gimp-plugin-template.
Have a look at the gauss blur plug-ins in the GIMP source tree. Also make sure you have the GIMP API reference manual available. It comes with the GIMP tarball (in the devel-docs directory) and is available online at http://developers.gimp.org/.
2004-05-03 12:48:36 UTC (almost 21 years ago)
Plug-in howto
Dave Neary writes:
Bartekk wrote:
i have a question about the development of plug-in. I want to use the plugin template u can get from the gimp site. The problem is I don't know which files are important. If I want to write a simple Gaussian Filter, how can I do that. Is there somebody who can give me an how to or an example.
This document is still somewhat valid, although the API has changed a lot since then, the principles are the same (the API changes are fairly evident in the plug-in template): http://gimp-plug-ins.sourceforge.net/doc/Writing/html/plug-in.html
I don't think we should point people to this document any longer. It's outdated and should better be removed. http://developer.gimp.org/ is where we are collecting more uptodate information and that's where people should be pointed to.
Dave Neary
2004-05-03 13:13:50 UTC (almost 21 years ago)
Plug-in howto
Sven Neumann wrote:
Dave Neary writes:
As part of preparing my guadec talk on writing a GIMP plug-in, I plan to update this document, so I'd prefer if it didn't get deleted just yet. In addition, it's quite nicely written with a type of tutorial feel, and it doesn't really have any homologue on the dgo site (yet).
Cheers, Dave.
2004-05-03 13:22:25 UTC (almost 21 years ago)
Plug-in howto
Dave Neary writes:
Well, dgo was started to finally give an alternative to this outdated sourceforge site, so please consider to help with dgo instead. It's in CVS, you have write access, feel free to improve it.
Dave Neary
2004-05-03 13:41:51 UTC (almost 21 years ago)
Plug-in howto
Sven Neumann wrote:
Dave Neary writes:
I'll commit the updated article from Kevin, plus my paper, plus my slides when I have them.
Cheers,
Dave.
Nathan Carl Summers
2004-05-03 22:43:13 UTC (almost 21 years ago)
Plug-in howto
On 3 May 2004, Sven Neumann wrote:
Dave Neary writes:
Do you have to run any weird scripts after you make changes, like you did with the old wgo? CCed to the list in the intrest of making the answer public knowledge.
Rockwalrus
David Neary
2004-05-03 22:55:43 UTC (almost 21 years ago)
Plug-in howto
Hi Nathan,
You don't *have* to run any scripts with the new wgo, by the way (although you probably should as a sanity check), the rebuild is done as a check-in hook. The same thing is true of the dgo site, but it helps to have a docbook XML set-up working, since this allows you to check for mistakes before committing.
Cheers, Dave.
Bartekk
2004-05-04 16:26:58 UTC (almost 21 years ago)
Plug-in howto
Hi Sven and Dave,
-----Original Message-----
From: Sven Neumann [mailto:neo@bender.convergence.de] On Behalf Of
Neumann
Sent: Monday, May 03, 2004 12:47 PM
To: Bartekk
Cc: Gimp Developer
Subject: Re: [Gimp-developer] Plug-in howto
I want to make a more difficult and complicated plug-in, but I have to start with a small and easy one. The idea to update the tutorial is fine. Maybe I will write a step by step how to for the newbie's.
Anyway, thanks for help
Thomas
