GIMPCon
GIMPCon Dave Neary 28 Apr 11:06
  GIMPCon Henrik Brix Andersen 28 Apr 16:42
   GIMPCon Dave Neary 03 May 10:52
  GIMPCon Daniel Rogers 29 Apr 18:16
Dave Neary
2004-04-28 11:06:02 UTC (almost 21 years ago)
GIMPCon
Hi all,
In a mail I just sent off, I said we should have some information about what we plan to do at GIMPCon...
What do we plan to do at GIMPCon?
Cheers, Dave.
2004-04-28 16:42:42 UTC (almost 21 years ago)
GIMPCon
Well, I think we should discuss the road map (or whatever you prefer to call it) for the release to come after 2.2 (2.4? 3.0?). We need to talk about stuff like PDB rewrite, GEGL integration, next generation XCF, plug-in policies etc.
We also need to talk about the GIMP Foundation and how it fits in with GIMP development.
These are the topics that come to mind right now - I am sure there a lots more...
Brix
Daniel Rogers
2004-04-29 18:16:06 UTC (almost 21 years ago)
GIMPCon
Dave Neary wrote:
Hi all,
I'd like to say that, for the record I won't be able to attend GimpCon. I simply don't have the time or money at the moment (and the soonest I would is months and months away).
And in case anyone missed my previous PS, I'm quite busy with my real life atm and have found myself quite without much time to put into The GIMP. Both setting up the bounties and the Foundation are things that are consuming all my free time.
-- Dan
Dave Neary
2004-05-03 10:52:42 UTC (almost 21 years ago)
GIMPCon
Is anyone actually working on a requirements list for a new PDB? It would be nice to know what exactly we expect from it, and whether the PDB should be refactored or re-written with gegl nodes in mind. Also, is there any way currently to have standalone out-of-process or threaded GeglNodes?
As to the next generation XCF, pippin has a pretty good file format which he is currently using with libgggl and bauxite, currently there is no competing format around.
For gegl migration, there has been quite a bit of talk already. Last I heard there were two ideas, which can generally be called data first or structure first - either we keep the same image data objects, and start using GeglGraphs for compositing first, then start changing data structures (I guess that going this way means turning GeglNodes into more or less an interface which delegate operations to a GIMP data based implementation, or to a gegl data based implementation, then eventually killing off the GIMP based ones)., or we change the data structures first (which implies that the data structures and the methods for accessing them are finished) and once we have the data in gegl, start migrating the internal compositing engine and plug-ins to GeglNodes.
There was no concrete decision out of the last conversation we had about this. Dan and Calvin's proposal to Mark Shuttleworth on bounties will help lay down tracks here, but it's currently looking unlikely that gegl will be ready to integrate into the GIMP this Sumemr at its current rate of change. Dan has said he'll have less time to spend on it from now on, which means that gegl right now needs some people to work on the data structures end.
If this doesn't happen soon, Calvin's proposition of migrating the rendering framework first, and following up with the data structures when they're done, will look a lot more attractive.
I recently posted a link to a requirements document that Lourens Veen did for plug-in distribution, but I haven't seen any comments on it. Again, this is one of those things that needs someone actually working on it, rather than just saying to ourselves "that needs to be done". I know yosh was thinking about this - perhaps he has comments?
I think that this will be resolved before GUADEC. I hope it will be resolved by the end of this week...
Cheers, Dave.
