conflict between 2.0 and 2.1
conflict between 2.0 and 2.1 William Skaggs 24 Apr 19:25
  conflict between 2.0 and 2.1 Sven Neumann 25 Apr 01:00
William Skaggs
2004-04-24 19:25:40 UTC (almost 21 years ago)
I'd like to bring up what appears to be a conflict between 2.0 and 2.1 that will become relevant as soon as a tarball of 2.1 is released. Building 2.1 causes the version info in pkgconfig/gimp-2.0.pc to be set to 2.1. This means that any plug-in built thereafter will be installed in 2.1, and there is no way to install new plug-ins for 2.0 without doing something kludgy.
Either that, or I'm missing something :-).
Best, -- Bill
2004-04-25 01:00:14 UTC (almost 21 years ago)
"William Skaggs" writes:
I explained the versioning scheme in a mail to this list. You obviously missed that. Here it is again:
The version number has been changed to 2.1.0. We plan to have the gimp-2.2 plug-in API completely backward compatible to gimp-2.0. Nevertheless most versions have been bumped to 2.1 for now. This is to avoid confusion when both the gimp-2.0 and the development branch are installed. It does _not_ mean that you can install gimp-2.0 and gimp-2.1 into the same prefix. The two installations are _not_ disjunct, you need to keep them in separate prefixes!
When we approch gimp-2.2, we will probably change most version numbers back to the GIMP API version which is 2.0.
