Re : Fwd : Re : Re : [Gimp -developer] spl ash pictur [jea n-luc.coulon@wa nadoo.fr]
14 of 15 messages available
splash picture and its container window Jean-Luc Coulon (f5ibh) 13 Mar 13:34
  splash picture and its container window Henrik Brix Andersen 13 Mar 13:47
   Re : [Gimp-developer ] splash picture and its container window Jean-Luc Coulon (f5ibh) 13 Mar 14:06
    Re Henrik Brix Andersen 13 Mar 14:11
     Re : splash picture and its container window Raphaël Quinet 13 Mar 14:55
    Re : [Gimp- developer] spla sh picture and its container w indow Sven Neumann 13 Mar 15:13
    Re : [Gimp-devel oper] splash picture and its container window David Neary 13 Mar 15:22
     Re : Re : [Gimp-de veloper] splash picture and its container window Jean-Luc Coulon (f5ibh) 13 Mar 15:35
20040313142802.GA14762@tang... 07 Oct 20:22
  Fwd : Re : Re : [G imp-developer] splash pictur [jean-luc.coulon@wanadoo.fr] Jean-Luc Coulon (f5ibh) 13 Mar 15:29
   Fwd : Re : Re : [Gimp-deve loper] splash p ictur [jean-luc .coulon@wanadoo .fr] Sven Neumann 13 Mar 16:20
    Re : Fwd : Re : Re  : [Gimp-developer ] splash pictur [jean-luc.coulon@wanadoo.fr] Jean-Luc Coulon (f5ibh) 13 Mar 16:42
     Re : Fwd : Re : Re  : [Gimp-developer ] splash pictur [jean-luc.coulon@wanadoo.fr] Alan Horkan 14 Mar 01:48
      Re : Fwd : Re : Re : [Gimp -developer] spl ash pictur [jea n-luc.coulon@wa nadoo.fr] Sven Neumann 14 Mar 02:31
       Re : Fwd : Re : Re : [Gimp -developer] spl ash pictur [jea n-luc.coulon@wa nadoo.fr] Alan Horkan 14 Mar 18:07
2004-03-13 13:34:26 UTC (about 21 years ago)
The spash picture is dispayed in a window where the system display a progress dialog for the loading process.
The container window for this spash picture has its width resized according to the with of the text line(s) displayed. This produces an a not nice "oscillating" effect on the screen. --
Regards
- Jean-Luc
2004-03-13 13:47:26 UTC (about 21 years ago)
Which version of The GIMP?
Under which locale are you running The GIMP?
Sincerely, Brix
2004-03-13 14:06:07 UTC (about 21 years ago)
Henrik,
So, I forgot: it is the 2.0-pre cvs version from 20040312.
Locale is fr_FR@euro, but I tried with LC_MESSAGES=C and got the same effect (less annoying anyway because the English sentences are mostly shorter).
Regards
- Jean-Luc
Sincerely,
Brix
2004-03-13 14:11:48 UTC (about 21 years ago)
Re
I can not reproduce the problem here using LANG=C. Can you provide a screen shot showing the problem?
./Brix
Raphaël Quinet
2004-03-13 14:55:22 UTC (about 21 years ago)
It probably depends on the font size that you are using. I could reproduce the annoying resizing problem by reducing the width of the splash screen in order to make the problem more obvious. Just edit $PREFIX/share/gimp/1.3/images/gimp_splash.png and make it smaller. You will then see the splash window getting wider and narrower during start-up.
I don't know if we should try to have a wider splash screen. Is this a real issue in many locales?
-Raphaël
2004-03-13 15:13:02 UTC (about 21 years ago)
"Jean-Luc Coulon (f5ibh)" writes:
Your font size got to be HUGE. I would suggest you start gimp using the --no-splash command-line option to workaround this problem.
PS: I am planning to do some changes to the splash window today or tomorrow. Should be trivial to work around this problem by cutting the text off if it's too wide.
David Neary
2004-03-13 15:22:07 UTC (about 21 years ago)
hi Jean-Luc,
So, I forgot: it is the 2.0-pre cvs version from 20040312. Locale is fr_FR@euro, but I tried with LC_MESSAGES=C and got the same effect (less annoying anyway because the English sentences are mostly shorter).
This may be a problem related to your desktop fonts. Here with fr_FR and en_UK or C I have no problem.
If you use a bigger font in your gtk+ theme, that might make the text wide enough to over-run the splash box.
What's your expected behaviour here. That the text be chopped at the edges of the splash, or that the window be big enough for the biggest string from the start?
Cheers, Dave.
2004-03-13 15:29:54 UTC (about 21 years ago)
Le 13.03.2004 15:28, Jean-Luc Coulon (f5ibh) a écrit : Le 13.03.2004 15:13, Sven Neumann a écrit :
I don't think my font size is so huge ;-)
I join (for you, not for the list, as requested by Henrik) a screenshot of what happens with the French locale.
I was not able, after lots of tries, to get a capture of the same thing with the C locale, I'm always out of sync: this happens only in one case, when it is loading the "Resource configuration" and the displayed path is too long, it is "/home/jean-luc/.gimp1.3/pluginrc" ; this text is larger that the width of the splash image so the windows width is increased accordingly.
*I* can survive with this "problem". It is not looking so pretty that's all ..
Regards
- Jean-Luc
2004-03-13 15:35:45 UTC (about 21 years ago)
Hi David,
Le 13.03.2004 15:22, David Neary a écrit :
hi Jean-Luc,
shorter).
This is the case, my font size is 12 8-)
*My* expected behaviour is ... nothing. I just *think* it would have a better "sex appeal" for the end user who is comming from an other software and who thinks the look is important.
Any of your suggestions is acceptable: - text cropped : motly nobody read it as it is moving very quickly - larger window can be *the* solution but you will have to fix/compute and acceptable width.
Regards
- Jean-Luc
Cheers,
Dave.
David Neary,
Lyon, France
E-Mail: bolsh@gimp.org
2004-03-13 16:20:57 UTC (about 21 years ago)
Well, your font isn't that huge but you've choosen a very wide font. It's of course up to you, but you will be suffering from this problem in all dialogs. I suggest you don't use an oblique font for your desktop.
2004-03-13 16:42:37 UTC (about 21 years ago)
Hi Sven,
Snifff ... I loved it ...
But you are right, in the past, I had a problem with the gnome-panel and italic fonts, the right-end character was truncated (fixed in gnome 2.6).
For The Gimp, with simple arial, up to 12, there is no problem.
While we are speaking of splash screen a 3:2 ratio or 4:3 ratio or "magic number" ratio rectangle instead of a square shape would looks even better, but it is a matter of taste ;-)
-- J-L
Alan Horkan
2004-03-14 01:48:49 UTC (about 21 years ago)
0
2004-03-14 02:31:43 UTC (about 21 years ago)
Alan Horkan writes:
PS How are the Splash and About images still PPM format* because I was wondering why they aren't in a smaller format like PNG? (* I dont have the latest copy of GIMP 2.0 handy otherwise I'd check)
Please get a recent copy then or refrain from commenting on our code. These files are PNG for more than 2 years now. You could have downloaded a new version in the meantime.
Of course we know about the problems that l10n can introduce. However the solution to this problem is not to add some arbitrary extra space but to adjust either the widget or the font size dynamically. Usually the widget is adjusted but for the about dialog we adjust the font size and I consider to do the same for the splash.
Alan Horkan
2004-03-14 18:07:52 UTC (about 21 years ago)
0
