choosing fonts
choosing fonts Gezim Hoxha 10 Mar 06:04
  choosing fonts Dave Neary 10 Mar 10:17
   choosing fonts Gezim Hoxha 11 Mar 02:43
    choosing fonts Simon Budig 11 Mar 03:06
    choosing fonts Sven Neumann 11 Mar 04:06
     choosing fonts Gezim Hoxha 11 Mar 07:10
Gezim Hoxha
2004-03-10 06:04:06 UTC (about 21 years ago)
choosing fonts
Hi all,
I find that when you have more than ten fonts and try to choose a good one, it takes lots of time because you have to click in everyone....blah..blah
If you could make a feature so one can youse the arrows on the keyboard and see how a font looks, and check out the next font instead of having to click so many times. Also adding "letter spacing" feature wouldn't be too bad.
Thanks for all your efforts,
Gezim
Do you Yahoo!?
Yahoo! Search - Find what you
Dave Neary
2004-03-10 10:17:18 UTC (about 21 years ago)
choosing fonts
Hi Gezim,
In the drop-down box from the text tool font button, there is a button "Open the font selector dialog". This dialog allows navigation by arrow keys. This is also a dockable, so you can add it to the dock beside (say) paint brushes so that it is easily accessible while you are using the text tool.
Hope this helps, Dave.
Gezim Hoxha
2004-03-11 02:43:02 UTC (about 21 years ago)
choosing fonts
I've tried this before, but I don't get the wanted results. When the "font selection dialog" opens I click on fonts, and use the arrow key but the font type on the current selected text layer doesn't change. Does it need configuring in anyway?
Do you Yahoo!?
Simon Budig
2004-03-11 03:06:54 UTC (about 21 years ago)
choosing fonts
Try doubleclicking on the text layer in the layers dialog. Then the fonts dialog should change the font on that layer.
Hope this helps, Simon
2004-03-11 04:06:23 UTC (about 21 years ago)
choosing fonts
Gezim Hoxha writes:
It does need a recent version of The GIMP (2.0pre4).
Gezim Hoxha
2004-03-11 07:10:44 UTC (about 21 years ago)
choosing fonts
That explains it. I've got 2.0-pre3-r1 right now coz in gentoo pre4 is not yet here. So something to look forward to.
Do you Yahoo!?
