Re  :  Printing with gimp 2.0 German
        Le 09.03.2004 20:39, Frank Noack a écrit :
Hi
The print output from gimp2.0pre4 "german" is also buggy like in the
previous
versions. If i like to print with gimp with LANG=en is all ok. If i
use
LANG=de_DE@euro it does not work. With the same printer preferences
"Cups
with turboprint"
printername - Stylus640,
printer - PostScript Level 2,
command - lp -s -dStylus670,
pppd-file - /usr/share/cups/model/turboprint/Epson_StylusColor670.ppd
it works with english language.
But if i change to german i get no preview.
The developers from turboprint mean its a bug in the "translation" of
floatingpoint numbers if using german. It "translates" the decimal
point to a
decimal comma.
Knows anybody something about this?
Thanks Frank
The locale that fixes the decimal is LC_NUMERIC.
The value for this for fr_FR ou de_DE is the comma.
I suppose the bug is in Turboprint which is not aware of the locale. A
call to setlocale() should be done in this program ...
A quick fix is to use LC_NUMERIC=C in your environement. Doing so you
will get everywhere a dot instead of a comma as a decimal separator
which is IMHO harmless.
Regards
			- Jean-Luc
