updated GIMP API Reference Manuals
updated GIMP API Reference Manuals Sven Neumann 26 Feb 02:22
2004-02-26 02:22:18 UTC (about 21 years ago)
just a quick note to let you know that I finally got around to update the online version of the GIMP API Reference Manuals at developer.gimp.org. The manuals moved from api/1.3 to api/2.0 since we now consider the 2.0 API to be final. Yosh installed a permanent redirect, so old links should continue to work but if you linked to the 1.3 docs, would you please update your links nevertheless.
So the updated docs can be found here:
http://developer.gimp.org/api/2.0/
