Patch to remove deprecated constants from standard scripts
Patch to remove deprecated constants from standard scripts Kevin Cozens 03 Feb 00:33
  Patch to remove deprecated constants from standard scripts Henrik Brix Andersen 03 Feb 00:42
   Patch to remove deprecated constants from standard scripts Kevin Cozens 03 Feb 05:17
    Patch to remove deprecated constants from standard scripts Sven Neumann 03 Feb 10:49
     Patch to remove deprecated constants from standard scripts Kevin Cozens 04 Feb 04:09
Kevin Cozens
2004-02-03 00:33:19 UTC (about 21 years ago)
Greetings.
I have a patch which removes all of the deprecated named constants from the Script-Fu based scripts which are part of a standard GIMP installation.
I haven't attached the patch to this message since it is a bit over 50,000 bytes. The patch file is available with the following URL: http://pages.interlog.com/~kcozens/software/gimp/1.3/scripts.patch
If necessary, I can create a bug report in bugzilla and attach the patch to the report.
2004-02-03 00:42:27 UTC (about 21 years ago)
On Tue, 2004-02-03 at 00:33, Kevin Cozens wrote: [snip]
Please do that - bugzilla helps us track bugs along with patches and enhancement requests much better than a mailing list does.
Sincerely, Brix
Kevin Cozens
2004-02-03 05:17:56 UTC (about 21 years ago)
Done. The patch affects 48 different scripts. It will allow for the eventual removal of some code in siod-wrapper.c (for the 2.2 release?).
2004-02-03 10:49:49 UTC (about 21 years ago)
Kevin Cozens writes:
I don't think we want to break backward compatibility so this code will have to stay.
Kevin Cozens
2004-02-04 04:09:28 UTC (about 21 years ago)
The code should certainly stay for the 2.0 release. I have made a script available that makes it easy to update scripts to the latest API. The compatibility could be removed as of 2.2 since we don't want to keep it indefinitely. However, the when isn't up to me unless I do come up with something to replace the existing Script-Fu extension.
BTW, if you don't like the CHANNEL-OP enum, Sven, go head and change it. Let me know what you change it to in the rest of the system so I can ensure the Script-Fu system accepts the new constant and so I can update the standard GIMP scripts to use the new constant.
