Updated script to convert Script-Fu scripts to 2.0 API
Updated script to convert Script-Fu scripts to 2.0 API Kevin Cozens 03 Feb 00:25
Kevin Cozens
2004-02-03 00:25:42 UTC (about 21 years ago)
Greetings.
For those of you working with Script-Fu scripts for the GIMP, I have made a minor change to the Perl script I wrote to update scripts from the 1.2 to the 2.0 API.
The latest change allows named constants to be recognized (and updated as needed) regardless of whether they use _ or -. The script preserves the formatting of the original script and is safe to apply to scripts which already conform to the 2.0 API. It does not (yes?) add GIMP- to the start of constants as was being discussed in recent postings.
The core developers are free to use this script as a replacement for the plug-ins/script-fu/convert-script if they so choose.
