[patch]Gimp plug-in template 1.3.2 won't compile
[patch]Gimp plug-in template 1.3.2 won't compile Kevin Cozens 01 Feb 05:46
  [patch]Gimp plug-in template 1.3.2 won't compile Manish Singh 01 Feb 09:28
   [patch]Gimp plug-in template 1.3.2 won't compile Kevin Cozens 01 Feb 18:03
    [patch]Gimp plug-in template 1.3.2 won't compile Sven Neumann 02 Feb 14:48
     [patch]Gimp plug-in template 1.3.2 won't compile Kevin Cozens 02 Feb 17:24
Kevin Cozens
2004-02-01 05:46:35 UTC (about 21 years ago)
Greetings.
The 1.3.2 of the sample plug-in (gimp-plugin-template) uses some features that are deprecated in the latest CVS version of the GIMP. It is also missing an argument to one function call. The attached patch allows the template plugin to compile.
Manish Singh
2004-02-01 09:28:28 UTC (about 21 years ago)
On Sat, Jan 31, 2004 at 11:46:35PM -0500, Kevin Cozens wrote:
Greetings.
Thanks, but these have already been fixed in gimp-plugin-template CVS for some time already.
-Yosh
Kevin Cozens
2004-02-01 18:03:59 UTC (about 21 years ago)
Greetings.
If it wasn't for the fact that I am usually up late, I'd blame the confusion on my being up late.
To clarify, I have started looking at porting Guash to the 2.0 API. I didn't know if anyone else is doing it but I would like it and it would be a good learning exercise. I wanted to have the sample plug-in to look at as a template.
I found a link to the template on developer.gimp.org so I have a released tarball and not a copy from a CVS repository. The sample template uses features that are deprecated in the latest CVS copy of GTK+ (I didn't mean to say GIMP in my original message).
If these things have been fixed, sounds like its time to release a new tarball. Also, any chance of a sample template that isn't tied to an Image (ie. one that attaches to )?
Cheers!
Kevin. (http://www.interlog.com/~kcozens/)
Owner of Elecraft K2 #2172 |"What are we going to do today, Borg?" E-mail:kcozens at interlog dot com|"Same thing we always do, Pinkutus: Packet:ve3syb@ve3yra.#con.on.ca.na| Try to assimilate the world!" #include | -Pinkutus & the Borg
2004-02-02 14:48:23 UTC (about 21 years ago)
Kevin Cozens writes:
Given the state of the guash code and that it never got the reputation of being stable, I'd advocate to write a new plug-in instead of attempting to port this code. I've been playing with a thumbnail browser plug-in to make some more use of libgimpthumb. So far it's a command-line tool only but it could be interesting to add a GUI to it. In the end this plug-in could come quite closely to what guash used to do.
If you had a look at the CVS version it would have been clear to you that the new tarball is around the door.
Kevin Cozens
2004-02-02 17:24:41 UTC (about 21 years ago)
The GUASH code looks a little messy too and could stand some clean up or splitting in to several files. I don't know which way I will go with this yet. Thanks for pointing out libgimpthumb. Sounds like that could be useful.
I would have looked at the CVS copy I had known it was in CVS at the time. Anyway, thanks for the new tarball. I'll grab a copy of it in a little while.
Cheers!
