Re  : CVS doesnt compile
CVS doesnt compile Jean-Luc Coulon (f5ibh) 21 Jan 14:25
  CVS doesnt compile Sven Neumann 21 Jan 14:35
   Re  : CVS doesnt compile Jean-Luc Coulon (f5ibh) 21 Jan 21:26
2004-01-21 14:25:26 UTC (about 21 years ago)
CVS doesnt compile
I got the following error:
Making all in tips make[2]: Entering directory `/usr/local/src/gimp-1.3.cvs/tips' INTLTOOL_EXTRACT=../intltool-extract ../intltool-update --gettext- package gimp20-tips --pot
can't open Makefile.in.in: Aucun fichier ou répertoire de ce type at ../intltool-update line 952.
make[2]: *** [gimp20-tips.pot] Erreur 2 make[2]: Leaving directory `/usr/local/src/gimp-1.3.cvs/tips' make[1]: *** [all-recursive] Erreur 1 make[1]: Leaving directory `/usr/local/src/gimp-1.3.cvs' make: *** [all] Erreur 2
Regards
- Jean-Luc
2004-01-21 14:35:07 UTC (about 21 years ago)
CVS doesnt compile
"Jean-Luc Coulon (f5ibh)" writes:
You are using intltool-0.29, a version that is unfortunately broken. Version 0.28 will work but it's know to produce a broken gimp-tips.xml file. If you want a working version of intltool, please downgrade to intltool-0.27.2.
2004-01-21 21:26:55 UTC (about 21 years ago)
Right guess ..
Well I've reinstalled 0.28 because I had a backup package for my Debian sid but I've not 0.27 anymore ... And it seems to work, at least to compile.
Thanks and regards
- Jean-Luc
