Re : Re : [Gimp-de veloper] CVS Hanuary 16th, 2004 failed to build
CVS Hanuary 16th, 2004 failed to build Jean-Luc Coulon (f5ibh) 16 Jan 22:18
  CVS Hanuary 16th, 2004 failed to build David Neary 16 Jan 22:36
   Re : [Gimp-developer ] CVS Hanuary 16th, 2004 failed to build Jean-Luc Coulon (f5ibh) 16 Jan 22:53
    Re : [Gimp- developer] CVS Hanuary 16th, 2 004 failed to b uild Sven Neumann 16 Jan 23:34
     Re : Re : [Gimp-de veloper] CVS Hanuary 16th, 2004 failed to build Jean-Luc Coulon (f5ibh) 17 Jan 00:07
Re : Re : [Gimp-de veloper] CVS Hanuary 16th, 2004 failed to build Jean-Luc Coulon (f5ibh) 16 Jan 23:51
2004-01-16 22:18:03 UTC (over 21 years ago)
I got the following error:
make[3]: Entering directory `/usr/local/src/gimp-1.3.cvs/app/gui' if gcc -DHAVE_CONFIG_H -I. -I. -I../.. -I../.. -I../.. -I../../app - I../../app -I/usr/local/include/glib-2.0 -I/usr/local/lib/glib-2.0/ include -I/usr/include/gtk-2.0 -I/usr/lib/gtk-2.0/include -I/usr/ include/atk-1.0 -I/usr/include/pango-1.0 -I/usr/include/freetype2 -I/ usr/X11R6/include -I/opt/gimp1.3/include -DG_LOG_DOMAIN=\"Gimp-GUI\" -DG_DISABLE_DEPRECATED -DGDK_PIXBUF_DISABLE_DEPRECATED - DGDK_DISABLE_DEPRECATED -DGTK_DISABLE_DEPRECATED -DGDK_MULTIHEAD_SAFE - DGTK_MULTIHEAD_SAFE -g -O2 -Wall -MT edit-commands.o -MD -MP -MF ". deps/edit-commands.Tpo" \
-c -o edit-commands.o `test -f 'edit-commands.c' || echo './'`edit- commands.c; \
then mv -f ".deps/edit-commands.Tpo" ".deps/edit-commands.Po"; \ else rm -f ".deps/edit-commands.Tpo"; exit 1; \ fi
edit-commands.c:139: error: conflicting types for `edit_paste_cmd_callback'
edit-commands.h:32: error: previous declaration of `edit_paste_cmd_callback'
make[3]: *** [edit-commands.o] Error 1 make[3]: Leaving directory `/usr/local/src/gimp-1.3.cvs/app/gui' make[2]: *** [all-recursive] Error 1 make[2]: Leaving directory `/usr/local/src/gimp-1.3.cvs/app' make[1]: *** [all-recursive] Error 1 make[1]: Leaving directory `/usr/local/src/gimp-1.3.cvs' make: *** [all] Error 2
Regards
- Jean-Luc
David Neary
2004-01-16 22:36:32 UTC (over 21 years ago)
It is possible that the anoncvs server you're using has an inconsistent repository. To verify this, could you run "cvs status edit-commands.[ch]" in app/gui? The revisions should be
=================================================================== File: edit-commands.c Status: Up-to-date
Working revision: 1.41
Repository revision: 1.41
/cvs/gnome/gimp/app/gui/edit-commands.c,v Sticky Tag: (none)
Sticky Date: (none)
Sticky Options: (none)
=================================================================== File: edit-commands.h Status: Up-to-date
/cvs/gnome/gimp/app/gui/edit-commands.h,v Sticky Tag: (none)
Sticky Date: (none)
If you have another version of either of these files, you might have to wait until tomorrow to get back to a consistent state.
As an alternative, try using anoncvs3.gnome.org rather than anoncvs.gnome.org for your CVS updates, as there is one known dodgy anoncvs mirror in the mix.
Cheers, Dave.
2004-01-16 22:53:34 UTC (over 21 years ago)
Working revision: 1.41 Repository revision: 1.41
Sticky Date: (none)
Working revision: 1.4 Repository revision: 1.4
Sticky Date: (none)
Cheers, Dave.
Seems to be the case:
[jean-luc@tangerine] ~/CVS-sources/gimp/app/gui $ cvs status edit- commands.[ch]
Working revision: 1.41 Repository revision: 1.41 /cvs/gnome/gimp/app/gui/edit-commands. c,v
Sticky Tag: (none)
Sticky Date: (none)
Working revision: 1.3 Repository revision: 1.3 /cvs/gnome/gimp/app/gui/edit-commands. h,v
Sticky Tag: (none)
Sticky Date: (none)
Thanks, I will wait until tomorrow, I'm not in a hurry ;-)
-- - Jean-Luc
2004-01-16 23:34:38 UTC (over 21 years ago)
"Jean-Luc Coulon (f5ibh)" writes:
Waiting until tomorrow will not necessarily fix it. The problem is that there are two anoncvs servers and one of them is broken. If you are using anoncvs.gnome.org you are using a DNS round-robin:
$ host anoncvs.gnome.org anoncvs.gnome.org has address 130.239.18.151 anoncvs.gnome.org has address 138.100.8.6
The second one is broken for quite a while already. You better use anoncvs.gimp.org which is an alias for the first (usually very well-working) anoncvs server.
2004-01-16 23:51:55 UTC (over 21 years ago)
Ok, thank you, I'm retrying with anoncvs.gimp.org .. I got a very different tree :-/
Regards
- Jean-Luc
2004-01-17 00:07:34 UTC (over 21 years ago)
I've downloaded the cvs version from gimp.org but I got the same wrond version for the files indicated by David : [jean-luc@tangerine] ~/CVS-sources/gimp/app/gui $ cvs status edit- commands.[ch]
Sticky Tag: (none)
Sticky Date: (none)
Sticky Tag: (none)
Sticky Date: (none)
-- Regards
- Jean-Luc
