Dithering
12 of 12 messages available
Dithering David Gómez 07 Jan 21:28
  Dithering Sven Neumann 07 Jan 21:43
   Dithering Manish Singh 07 Jan 22:25
    Dithering David Gómez 07 Jan 23:00
   Dithering David Gómez 07 Jan 23:03
    Dithering Austin Donnelly 20 Jan 17:39
     Dithering Sven Neumann 20 Jan 17:48
      Dithering Daniel Egger 21 Jan 20:10
       Dithering Adam D. Moss 21 Jan 20:28
        Dithering Daniel Egger 21 Jan 22:01
  Dithering David Neary 07 Jan 21:47
   Dithering David Gómez 07 Jan 22:37
David Gómez
2004-01-07 21:28:29 UTC (almost 22 years ago)
Dithering
Hi all,
Just installed gimp-2.0pre1 ;)
I've scanned some jpeg images with a 24bit depth. Some of them are old photographies in black&white that show 'bands' when are displayed on a 16 bit depth display. After digging in the menus i noticed that the image could be transformed to a indexed pallete, with a Floyd-Steinberg dithering, but that did not solve nothing, the maximum number of colors cannot be set to more that 256 :-/. Is there another way to dither an image in gimp? Programs like gqview, an image viewer, use the dither algorithms bundled with gdx_pixbuf in gtk2, and they work perfectly with the same images. Why cannot the gimp do the same quality dithering if it's using the same library?
Thanks,
2004-01-07 21:43:09 UTC (almost 22 years ago)
Dithering
David Gómez writes:
The GIMP display canvas uses the dithering routines from GdkRGB which is probably what you are refering to. Of course this does only affect the display, not the image data. I am not sure but I think I remember a plug-in that could apply dithering to RGB images w/o converting to Indexed colors.
David Neary
2004-01-07 21:47:33 UTC (almost 22 years ago)
Dithering
Hi David,
This is a normal phenomenon when moving to higher bitdepths. Unless you're talking about 16 bits in total, and not 16 bits per channel, in which case I'd be a bit mystified...
Floyd-Steinberg dithering is basically a way to approximate more colors with a smaller palette... it does not actually do anything like what you are expecting (as you have noticed).
Have you tried blurring the image with a radius of 0.5 or 1.5 pixels? This sometimes works quite well.
Oh, I see what you mean, I think - you're talking about the rendering of the data, you don't actually want to change the underlying data, you want it to look better. Is that right?
If that's the case, then I'm afraid the answer is that I don't know. I thought we used a GdkPixbuf, so if we don't I'm stumped :)
Cheers,
Dave.
Manish Singh
2004-01-07 22:25:32 UTC (almost 22 years ago)
Dithering
On Wed, Jan 07, 2004 at 09:43:09PM +0100, Sven Neumann wrote:
David G??mez writes:
Actually, gqview defaults to GDK_RGB_DITHER_NORMAL whereas gimp uses GDK_RGB_DITHER_MAX always, which should theoretically do a better job. Maybe you could put up a sample image somewhere so we can see what exactly the problem is?
-Yosh
David Gómez
2004-01-07 22:37:43 UTC (almost 22 years ago)
Dithering
Hi David ;),
Yes, i meant 16 bits per channel ;)
Yup, i already noticed that. Maybe i'm wrong, so please correct me, but the Floyd-Steinberg is implemented by the gimp, and the dithering in gdk_pixbuf (the paramater XlibRgbDither to functions like gdk_pixbuf_draw) are different things, isn't it?
I've tried it without success. The bands are too visible to be removed with a blur filter...
Yes, i want it to look better, and have the option to save the dithered image ;). Gqview does a dithering pass on the image, and the image looks great. I looked in the sources and saw that it doesn't implements any dithering algorithm, it just uses the underlying gdk_pixbuf dithering support.
I know that the Gimp is using GdkPixbuf, that's why i'm asking why it doesn't do a better dithering ;)
cheers,
David Gómez
2004-01-07 23:00:53 UTC (almost 22 years ago)
Dithering
Hi Yosh ;),
It should, certainly.
You're right, that would be the best. Please get it from:
http://david.pleyades.net/Explorar0044.jpg
It's has a size of 2.80Mb.
Hmmm..., don't bother to download it ;), i'm starting to see the cause of my problem. The image is quite big (2100x2800) and when the image is scaled to fit in the screen, the ugly 'bands' appears, but they aren't visible with a 1:1 zoom. I've scaled down the image and the bands are not there now.
So it seems the problem is with the zoom. When a big image is fitted to the screen size, it doesn't look nice (you know, bands ;)). What confused me was that gqview, with the same image size, fitted it to the screen size and no bands were drawed...
I think now is time for the gimp gurus to solve this zoom thing, i'll leave the image in the URL above some time in case somebody is interested ;)
Thanks all for your help ;),
cheers,
David Gómez
2004-01-07 23:03:43 UTC (almost 22 years ago)
Dithering
Hi Sven ;),
Yes i was referring to GdkRGB dithering, but it seems that was not the cause of the problem, as i said in my previous mail, and i was wrong thinking that was caused by gimp dithering implementation.
Thanks,
Austin Donnelly
2004-01-20 17:39:38 UTC (almost 22 years ago)
Dithering
That's because the screen display code doesn't smooth the image when it scales it, for speed reasons. Dedicated viewing programs can afford to do a better job showing the image because they won't be re-drawing it quite so often (imaging panning around the image while editing it - you'd like that to be fast, right?)
Austin
-----Original Message-----
From: gimp-developer-bounces@lists.xcf.berkeley.edu [mailto:gimp- developer-bounces@lists.xcf.berkeley.edu] On Behalf Of David Gómez Sent: 07 January 2004 22:04
To: Sven Neumann
Cc: Gimp-devel
Subject: Re: [Gimp-developer] Dithering
Hi Sven ;),
Thanks,
-- David Gómez
"The question of whether computers can think is just like the question of whether submarines can swim." -- Edsger W. Dijkstra
2004-01-20 17:48:09 UTC (almost 22 years ago)
Dithering
"Austin Donnelly" writes:
Well, actually we'd like to add interpolation to the GIMP canvas as well. At least optionally. Modern computer hardware seems fast enough to do this, especially when one takes advantages of CPU acceleration features (MMX, SSE, ...). Perhaps someone wants to tackle this task for GIMP-2.2?
Daniel Egger
2004-01-21 20:10:13 UTC (almost 22 years ago)
Dithering
- -----BEGIN PGP SIGNED MESSAGE----- Hash: SHA1
In OSX many applications tend to provide a quick redraw for pannings but start a timer which will refine the display once it was static for a while.
Servus,
Daniel
- -----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.2.4 (Darwin)
iQEVAwUBQA46CTBkNMiD99JrAQIGRQf/UWfxv7S9lxgybUrvm1U2CTUAGvSQLC2w uK6iUhZqirtQaBuzDTH23BEz5L/tzCoCf+7vJl11j1vZOpRZqE6H7kK8wmAb1i8T HKUthgScPGASocRHPevpF+u5cD3xBcbT2C6F6OXg/BEOOAFEm06gVIjaF7AOvEW3 x1L/zksyCxfZsAf2CYX845OnUAvXZZOZABaeXsUEqkQRJ7aXFQlcyMznMEx0w3U8 thp6VWtA2SlgcJmKk4nbTd06UHyoJY1XxSGR+OyRnICxS6grWC9UoBx2gXxMUmOG 9ib4yHKwD1EIUzNl4Cq18MQPUgh7UZ9/t1rWDcuVOBBeYtOGYamFTw== =KwxL
- -----END PGP SIGNATURE-----
-----BEGIN PGP SIGNATURE----- Version: GnuPG v1.2.4 (Darwin)
iQEVAwUBQA7OnzBkNMiD99JrAQKWyAgAouLPJ0cYHWBEySFPkRrnyXxVeVvJJsU1 kSe+WmD9d1a6aZyMZbqo2XkQb3+SP4aTYwBBv1oX9ZrKT02EkzRvGoxX1wvGmYBG Tp+l36e4YdVht3369Xl9qWrOvIvrX+3GcL0jXpY4M7B93FSwaeQr95Qy16k3g/mv 065AxzmR+d6d+rZQvmb271/JNFxDuc3GptuILgPueDsq3oakovq2cPkZBYcf+qcq bn92bkJiPgTVsT7TGBljP2+Zra586f57+i/96A0n1MntGUHkGfvs3IfvDNhz7Gua /nf2u2xlBNMaTynccIsvFI73C2rrDAsk/YeMEbgV/+adTPL+Y0Fmzg== =hOY/
Adam D. Moss
2004-01-21 20:28:02 UTC (almost 22 years ago)
Dithering
Hee hee... it's interesting how things can come full-circle. GIMP 0.5[34] did something very similar to provide a quick-render for interactive operations, re-rendering the results more nicely on the idle thread (undithered vs. dithered rather than aliased vs. interpolated, but for the same reasons).
--Adam
Daniel Egger
2004-01-21 22:01:22 UTC (almost 22 years ago)
Dithering
Am Mit, den 21.01.2004 schrieb Adam D. Moss um 20:28:
This would be my favourite solution rather than hope that the CPU is fast enough and someone wrote optimized code just to render a view that a human eye won't be able to trace in real-time anyway.
