Using gimpwire
Using gimpwire Shrinivas Kulkarni 15 Dec 05:03
  Using gimpwire David Neary 15 Dec 20:43
Shrinivas Kulkarni
2003-12-15 05:03:04 UTC (over 21 years ago)
Using gimpwire
Can anybody point me to examples about how to use gimpwire lib?
Thanks and regards, Shrinivas Kulkarni.
David Neary
2003-12-15 20:43:47 UTC (over 21 years ago)
Using gimpwire
Hi Shrinivas,
I don't know if there are any such examples outside GIMP cvs. Inside CVS, use of gimpwire is limited to libgimpbase/gimpprotocol.c, and that might be a good place to start. The functions in there are called from (among other places) app/plug-in/plug-in-message.c and libgimp/gimptile.c (which encapsulates most of the image data passing in the protocol).
Hope this helps, Dave.
