gimp-1.3.19 ./configure failure oddity
Greetings Gimp Gurus,
I have run into a baffling problem when trying to compile the gimp
(1.2.5 and 1.3.x) on a RH9 system. As far as I can tell, it seems
limited to the gimp: I can configure and compile other tarballs without
any problem. What makes it weird is the workaround. Details follow.
When I have /usr/local/lib in my search path (as I usually do, via
/etc/ld.so.conf and /sbin/ldconfig) the gimp configure step hiccups:
config.status: creating Makefile
config.status: creating config.h
./config.status: line 1332: 29673 Segmentation fault sed -f
$tmp/undefs.sed $tmp/in >$tmp/out
config.status: executing depfiles commands
and config.h doesn't get built. Somehow, somewhere, something is
crashing sed. If I take /usr/local/lib out of my library path, it all
works. My initial thought was that there were duplicate libraries
between /usr/lib and /usr/local/lib, but I haven't found any.
When I checked configure.log, there was no hint of any trouble.
I have noticed that /sbin/ldconfig complains that a number of
libgphoto_xxx.so.0 files aren't symlinks, but they all seem to be actual
executables. How this relates I have no idea.
An additional effect that I have noticed only with the gimp, is that
make crashes repeatedly during the compile. I was wondering if this
meant I was running out of temp disk, but I still have close to 2G left
on the root filesystem, so that isn't it; I have tried compiling with
and without /usr/local/lib in the ld.so.conf file and both compiles
crash (segfault) after compiling for a long time. Note that if I simply
reissue the make command the compile picks up where it left off, and
eventually I get a brand new gimp.
Has anybody seen problems like these, and can you suggest any possible
causes or other places to look? It's not a show-stopper, but it
certainly has been leaving me baffled.
TIA,
