Firmed out roadmap
Firmed out roadmap | David Neary | 25 Aug 22:22 |
Firmed out roadmap | Daniel Rogers | 26 Aug 00:33 |
Firmed out roadmap | Sven Neumann | 26 Aug 11:09 |
Firmed out roadmap | Sven Neumann | 26 Aug 10:58 |
Firmed out roadmap | Sven Neumann | 26 Aug 17:00 |
Firmed out roadmap | David Neary | 26 Aug 20:53 |
Firmed out roadmap | Sven Neumann | 27 Aug 01:29 |
Firmed out roadmap | Branko Collin | 27 Aug 14:03 |
Firmed out roadmap | David Neary | 27 Aug 20:22 |
Firmed out roadmap | Daniel Rogers | 26 Aug 22:13 |
Firmed out roadmap
Hi all,
Here is a roadmap with some meat on it (solid dates for milestones and other stuff) - it's pretty aggressive, particularly with respect to a 2.2 release next year.
I think experience has shown us that we will probably have a 2 to 3 month pre-release cycle where we only concentrate on bug fixing so for a 2.2.0 release to be sane for next Summer we need to think about going into pre-release mode in March or April, which means avoiding feature seapage around January and February, which means knowing what's going into 2.2.0 more or less straight after the 2.0 release :)
Some things need fleshing out - for instance, I'm not completely clear on the outstanding features to be implemented in the text tool before 2.0, or about the exact libgimp api changes that have been foreseen. Likewise, the recent thread on gimp-help-2 only served to confuse what little grasp I had on what was required before a release with respect to the help structure. It would be nice for people who know a little bit more about these things to address them specifically.
Also, it would be nice to have this marked up for the website, and I'm not sure I will have the time to do that in the near future. A volunteer to do that very small task would be appreciated :) Preferably using the stylesheets from mmaybe or developer.g.o.
You probably see that I had anticipated doing a release tomorrow (as anticipated at camp) as a prelude to a bug week... I just had a look, and make distcheck just failed on me in the po files, so I'm going to need to look more closely at that, and might not have a release until Wednesday or Thursday. I will keep track of the actual dates stuff gets done by as well :)
Anyway, comments are welcome. Is any of this unreasonable?
Cheers, Dave.
Roadmap for GIMP development:
Aug 6-10 2003: CCC
Aug 10th: 1.3.18 release
Aug 26th: 1.3.19 release
Sept 1st to Sept 8th: Bug week
Sept 27th: 2.0 pre1
Blockers for 2.0 prereleases: -----------------------------
Path tool features missing:
1) moving of strokes/paths,
2) being able to connect two strokes,
3) dragging on curve segments,
4) libart stroking,
5) im/export into files.
Text tool features missing:
Help browser features missing:
libgimp API changes missing:
Oct 18: 2.0 pre2
Nov 1: 2.0 pre3 (Halloween release)
Nov 22: 2.0 pre4 (possibly 2.0 final)
Around Dec 10th: 2.0.0
Jan 15th 2004: Final feature list for inclusion in 2.2.0
March 2004: Feature freeze
June/July 2004: 2.2.0 (just before GIMPCon)
August 2004: The Great Pain - the GeGL migration.
Firmed out roadmap
if you are missing .po files, just touch them (eg $ touch
po/missing-po-file.po) and you can build without the translations (po
files contain translatiosn of text in the gimp). I mentioned this
problem on IRC. carol straightened me out. If I felt braver, I would
commit those files empty files to the gimp so that other peoples builds
would work (though it would propably be better to remove support for
that language).
Dan
Firmed out roadmap
On Mon, 2003-08-25 at 22:22, David Neary wrote:
You probably see that I had anticipated doing a release tomorrow (as anticipated at camp) as a prelude to a bug week... I just had a look, and make distcheck just failed on me in the po files, so I'm going to need to look more closely at that.
I'd really like to see libgimpthumb going into the next release but I surely won't manage to finish this today. I was also suggesting to do a release before the end of the week though.
If you send me your output from 'make distcheck' I could probably help you to figure out that problem.
PS: Comments on the text tool later when I'm done with the rest of my mail...
Firmed out roadmap
On Tue, 2003-08-26 at 00:33, Daniel Rogers wrote:
if you are missing .po files, just touch them (eg $ touch po/missing-po-file.po) and you can build without the translations (po files contain translatiosn of text in the gimp). I mentioned this problem on IRC. carol straightened me out. If I felt braver, I would commit those files empty files to the gimp so that other peoples builds would work (though it would propably be better to remove support for that language).
ley.edu
The correct fix is to remove the offending language from ALL_LINGUAS in configure.in. Since gimp, unlike most other projects, has multiple translation domains, it happens quite frequently that a translators adds only a single po file for a new language and adds the new language to ALL_LINGUAS even though there are po files missing in po-libgimp, po-plug-ins and po-script-fu. This happened 2003-08-22 but Yosh removed the offending language from configure.in on the same day so I doubt that this was causing the problem for you. I have sent mail to the translator who broke the build explaining the situation and pointing him at README.i18n.
Firmed out roadmap
David Neary writes:
I really like the idea of setting a date for a feature freeze early. This allows people to prepare the code they want to get in and it makes it easy to reject stuff that comes to late. However I don't like the idea of setting release dates. While I think that your schedule is reasonable it should probably not be communicated outside this list and IMO the worst thing we could do would be to publish it on any web-site. This is a volunteers project. We don't know if we will be able to get 2.0 out in this timeline. There are too many unforseeable things that might happen. And who would benefit from any promised release-dates? IMO we can only hurt ourselves by doing such promises.
Don't get me wrong. I think your schedule is reasonable and we should definitely publish a roadmap but IMO it shouldn't include any dates.
Firmed out roadmap
Sven Neumann wrote:
David Neary writes:
Perhaps I should explain my reasoning behind putting firm dates behind things. Fair enough, setting release dates on a volunteer project is a recipe for disappointments when they are eventually missed, but if you look at the troubles we have had, they are echoed in other projects around the free software world - mozilla and GNOME being the two that come to mind immediately. When you say that the stable release will come whenever, then it really is whenever.
I feel that dates create a sense of urgency... 2.0 in December gets people thinking in the back of their minds that there's 4 months left to release. Put solid dates on there, and suddenly if a bug isn't classified by September 8th, it's not going to be fixed by 2.0, there are events associated with the near future.
I think that the dual goals of getting a release as soon as possible and getting as many people as possible working towards that release are served by setting dates. I'm not saying that these dates are set in stone - indeed, I expect them to slip because certain things are going to crop up - bugs that are blockers to 2.0, real life getting in the way of the blockers for the pre-release, and so on.
The basic idea I have is to (1) have rough dates when people can expect certain things to happen, and (2) maintain the roadmap so that those rough dates are never unrealistic. So when I say "release 26th of August", well if the release is on the 28th, I won't be disappointed, but I know that the bug week can't happen without the release. The idea of the roadmap is just to lay out the events that cannot happen in parallel. Fixing dates shows perhaps the most reasonable scenario. If we want a release before Christmas, then, we should be aware that there are only really 2 weeks of slack that we can play with.
I'm not saying that release dates solve lots of problems. They address a couple of problems. And they don't, in my opinion, create any, as long as the roadmap is updated to reflect reality.
Having said all that, if the general concensus is that we should not publish a roadmap with firm dates on it, I will modify what I have to be a bit fuzzier. But please note that a release schedule is not a stick I will use to beat people with. It is a tool to help us get to where we want to be. And to let people outside our little community know when we can expect to get there :)
Cheers, Dave.
Firmed out roadmap
what about sufficiently vague date?
Firmed out roadmap
just wanted to let you know that the tree seems to pass 'make distcheck' now. Well, at least up to the point very late in the process where it used to break for quite a while already... I don't want to delay 1.3.19 any longer, so the tree is basically fine for a release. Perhaps the NEWS file could need some touching. Let me know when you think it's time for a tarball...
Firmed out roadmap
On 26 Aug 2003, at 20:53, David Neary wrote:
Sven Neumann wrote:
David Neary writes:
The trouble with the road to 1.4/2.0 was (if I, as a non-programmer, see this correctly) that the whole of the GIMP had to be changed. It was not possible to release 2.0 piecemeal, the change of 1.2 to 2.0 as the stable version had to be in one go.
If I understand this correctly, this won't be the case with the change to GEGL, and even if it will be, there will be plenty of time to adapt to an upcoming GEGL.
May I suggest, therefore, that major new stable releases be produced every time a few major features are added or a few major changes are made? You are now able to break free from the mindset that ruled the change from 1.2 to 2.0, and that basically made the GIMP a cathedral in a world full of bazaars.
Release dates are cool, and targets too, but in the end, if there's a spiffy new feature, I want it in my GIMP.
Firmed out roadmap
Personally, I think we coould have developped some of the features in the current HEAD outside the main repository, and released something less featuresome earlier. But the code reorganisation and GObjectification (the major change in this release) was always going to take a long time. Particularly since so few people were working on it.
There will be pain with the changeover to gegl. I think that if we limit ourselves just to switching to gegl, we can get a release with gegl pretty quickly after 2.2, though.
Are you advocating a major release per feature? Or a thawing of the stable release to allow features as well as bug fixes to go in there? Or am I missing the point completely?
Cheers, Dave.
