libgimp or libgimpui
As noticeable from recent ChangeLog entries there
is some misunderstanding which functions belong
into libgimp and libgimpui.
My (mis)understanding so far was :
libgimpui : everything which has or provides a user
interface
libgimp : no UI; exception maybe some user interface
provided by The Gimp core via PDB, cause
the generated PDB wrappers live there, too.
The functions in question are
gimp_{brush,font,gradient,pattern}_select_{destroy,new}
which I have put into libgimpui without noticing that
Makefile.am (which my windoze build does not use) has them
in libgimp.
But after noticing to me it appears to be a bug in
Makefile.am not to list them for libgimpui ...
Is there a simple design rule to follow or is the rule that
Makefile.am is always right ?
Oh while we are at it: shouldn't gimp_plug_in_get_path()
be moved from gimpmiscui.c to gimpmisc.c ?
Thanks,
Hans
-------- Hans "at" Breuer "dot" Org -----------
Tell me what you need, and I'll tell you how to
get along without it. -- Dilbert
