[FEATURE] Some plug-in settings should be persistent accross sessions
[FEATURE] Some plug-in settings should be persistent accross sessions | David Neary | 25 Jul 22:23 |
[FEATURE] Some plug-in settings should be persistent accross sessions | Raphaël Quinet | 05 Aug 09:45 |
[FEATURE] Some plug-in settings should be persistent accross sessions | Marc) (A.) (Lehmann | 05 Aug 11:51 |
[FEATURE] Some plug-in settings should be persistent accross sessions | Raphaël Quinet | 05 Aug 14:03 |
[FEATURE] Some plug-in settings should be persistent accross sessions | Marc) (A.) (Lehmann | 05 Aug 15:02 |
[FEATURE] Some plug-in settings should be persistent accross sessions | David Neary | 05 Aug 16:09 |
[FEATURE] Some plug-in settings should be persistent accross sessions | Robert L Krawitz | 06 Aug 02:28 |
[FEATURE] Some plug-in settings should be persistent accross sessions | Alan Horkan | 25 Jul 23:06 |
Hi all,
http://bugzilla.gnome.org/show_bug.cgi?id=63610
Notably the Gif and Jpeg plug-ins have defaults which people change fairly frequently.
It would be nice if preferences for plug-ins survived session changes. The way to do this might be in saving them to an rc file without providing an interface to changing them in the normal preferences dialog (this might be handy enough although Sven might have something to say about it).
Basically some discussion is needed. Currently, the jpeg defaults suck. I would suggest following the advice in this bug and changing the default quality to 85%. Currently this is hard-coded in the plug-in.
If someone were to spend a bit of time figuring out how we could do this better (and reporting here, and claiming the bug) that would be great.
Cheers,
Dave.
In another bug report (which I am having difficulty finding) a users complians of being asked too many questions during Save.
To solve this i suggested that there should be a section in Preferences
allowing you to set save options on the basis that you dont need to set
these options every time you save, usually you will want to use the same
ones most of them.
There would also need to be an [Options] button in the save dialog to
access it quickly and change a save option when needed.
I would be very much in favour of having a Prefernces section Export (and possibly Import). Hopefully I can help recommend how this might be added. I would be inclined to push the feature request to Future.
Sincerely
Alan Horkan http://advogato.org/person/AlanHorkan/
Original message included below: [and list digest options finally changed to MIME so i can reply to stuff properly in future]
To: Gimp Developer List
Subject: [Gimp-developer]
Message-ID:
Content-Type: text/plain; charset=iso-8859-15
MIME-Version: 1.0
Precedence: list
Message: 11
Hi all,
Cheers,
Dave.
I doubt that we can do this in the Right Way before the next release. Saving these preferences should be done by the core through a well- defined interface. That's why I added a dependency on bug #101604, which tracks the changes to the PDB and plug-in API.
This is something that can be done easily. In fact, I have just done it. I have increased the default quality to 85%, which seems to be a better default for most (?) users. I have just committed this tiny change to CVS. This should take care of the most annoying part of this problem, while the bigger issues can be taken care of later.
-Raphaël
Maybe I misunderstand the problem, but all perl-plug-ins can do that (and do that by default) without any extra interfaces, using parasites, for ages.
They do that by default, though, and there is no UI to decide when to save - every invocation will overwrite the per-image and global defaults for the next invocation.
For the plug-in writer this is fully transparent (if she uses Gimp::Fu).
Yes, parasites are one part of the solution.
Look at the comment that I recently added in: http://bugzilla.gnome.org/show_bug.cgi?id=119032 IMHO, global parasites and immediate changes to the settings could make sense for the plug-ins that are used as filters, but not for the file plug-ins. For the file plug-ins, the settings should be a per-image property that is not affected by the changes made to the other images. Otherwise, it would not be possible to work on two images at the same time and to save them with their own settings without being afraid of having the settings of one image affecting the other one(s).
It is unfortunate that the file plug-ins and the other filters are all called "plug-ins", because they behave differently. What may make sense for the filters (global settings) may be counter-productive for the file plug-ins. For the filters, the settings can be considered to be a property of the filter itself: it is reasonable to expect that applying the same filter to a different image will use the same settings as last time. However, this is different for the file plug-ins: the quality settings, image comments and other meta-information is a property of the image itself, not a property of the filter. I expect these values to remain unchanged while I work on an image, even if I open and save other images in the meantime.
This confusion between what is the "right" behavior for a filter and for a file plug-in has caused some problems before. See for example: http://bugzilla.gnome.org/show_bug.cgi?id=75398 Although I fixed that bug last year, I think that the origin of the confusion was related to the concept of "current settings" for the JPEG plug-in. If it was clear that the current settings for the file plug-ins are per-image and not a global, then these problems would be solved.
Some settings such as the image comment and other meta-data should be available from a File->Properties dialog, not when the file is saved (http://bugzilla.gnome.org/show_bug.cgi?id=61499). This would make it more obvious that they are per-image.
In fact, the other settings related to the file format could also be dynamically registered as additional tabs in the meta-data editor. This is a bigger change that should probably be discussed this week at GimpCon, but the save plug-ins would not need their own dialogs and the Export feature could also be simplified. This would reduce or even get rid of the dialogs displayed when a file is saved (there are several bugs related to that). In addition, each tab could contain the buttons "Reset to defaults" and "Save as new defaults". The user would then understand easily when the changes are saved for later and when they are not. These buttons would only apply to the settings for the current tab, not to the whole properties. This would provide an easy way to replace the image comment of an existing file by whatever you have set as the default: you would go to the tab containing the image comment and click on "Reset to defaults" (currently, you have to copy and paste from the Preferences). If you want to set the JPEG quality to 95% for your image, you would go to the JPEG options tab, change the value and click on "Save as new defaults". The metadata dialog could pop up automatically (showing the JPEG tab) when a JPEG file is saved. Or not, if the user does not want to be bothered by this extra dialog. But it would be nice if the same dialog used for File->Properties would be re-used when saving the file. Note that I am thinking aloud here and there are plenty of details that should be ironed out (e.g., what is done by the core, what is done by the save plug-ins, how to add tabs dynamically to the meta-data editor), but this could IMHO improve the way the file plug-ins work.
Yes, this is nice. However, I am not sure that modifying the defaults every time (without user confirmation) is a really good idea. I would prefer this to be a conscious decision from the user. This affects the gimp-perl plug-ins only, but currently two users following the same tutorial (on the web, or printed in a book or magazine) might get different results because of what they did previously. This would be fine if they knew why (e.g., they had explicitely saved a default set of options) but this is not so obvious now.
-Raphaël
As I said (or wanted to say, but didn't :): the perl plug-ins do exactly that, as tehy attach themselves as global and per-image parasite.
the problem in pelr is the UI. When I added buttons for the various options to recall defaults it became a bit complicated for the user to understand.
Your proposal to have two difefrent default strategies (not reflected in the UI of the plug-in), i.e. file == per-image and global, filters == global only (the latter is not gimp-perl's behaviour, though) might make a lot of sense without cluttering the UI.
Personally, I think it's equally reasonable to have the same settings as used on the same image earlier, though. Both are equally useful to me.
For file-plug-ins, a fallback to the global default is also useful, although not as useful as with filters.
What would be good would be a clever way to enable the user to chose, and have sensible defaults so the user need not to in most cases.
It as, at best, a good guess of what should be done. gimp-perl was mostly modelled after what other plug-ins do in the case of LAST_RUN_VALS.
There is always the button to reset to defaults (and another button to use the previous values). Adding more buttons was not possible (clutter), while a menu with various choices is not quick to use.
Snipping most of this because there's not enough time :)
The behaviour should be...
Save As -> Open file dialog with same setting that were used the last time the Save As dialog was used (same as "Reshow last" for filters).
Save -> Use the per-image parasites which were attached.
This means that if you save 2 images as jpeg through the Save As menu item, if you changed the quality to 95 for the first, the slider will be at 95 for the second. However, if we then reduce the quality for the second to 70, then do a File->Save of the first image, the quality will be at 95 for the original image, since the parasite attached to the image trumps the last used settings for the dialog.
Currently, if you File->Open a jpeg which was saved with 98% quality, then File->Save, the image is unusable for printing, since it's saved with 70% quality with no user intervention. In this case, when saving a jpeg with no jpeg_save_vals parasite attached, we should pop up the Save As dialog. That, or we read the quality setting from the file at load time, rather than attaching the default crummy quality as we do now.
One way to get the expected save as behaviour would be for a plug-in to register the last values used with the core when it's finishing up, and those values be sent as parameters for the next interactive run.
Sure, but people expect not to have to change the settings every time - if they change the settings in the Save As dialog for a file type, those settings are expected to stay as the defaults for the next time they use the dialog.
It seems to me that your idea of per-plug-in metadata tabbed dialog thingy is a complicated interface. There is no need for most of that stuff to be exposed, and there are potentially dozens of tabs which would register options for it. It seems to me far simpler to stick with the "normal" behaviour that when a dialog pops up, the values in the dialog are the same as they were the last time it popped up. This has the added benefit of being easier to implement too :)
To make it persistent across sessions, we could just dump everything into a readable gimprc file which the user could modify afterwards if he wanted. But he wouldn't have to. And we probably wouldn't want him to :) There would be no need, imho, to re-complicate our newly cleaned up preferences dialog with a 50-tab "file prefereces" window.
Cheers, Dave.
Date: Tue, 5 Aug 2003 14:03:09 +0200 From: =?ISO-8859-1?Q?Rapha=EBl?= Quinet
The Print plugin has yet another behavior; the settings are per-printer, not per-file. Conceivably they could wind up being shared with other applications that use Gimp-Print.
