[FEATURE] Layer movement independent of layer mask
[FEATURE] Layer movement independent of layer mask David Neary 25 Jul 21:57
David Neary
2003-07-25 21:57:10 UTC (over 21 years ago)
Hi all,
http://bugzilla.gnome.org/show_bug.cgi?id=91941
This feature request is for a way to de-couple layerr movement and layer mmask movement (more details in the bug). The idea would be that you could draw a mask, and if you positioned it incorrectly at the start, you could just move it. Currently, the only way is to convert the mask to a float, move it, and then anchor it again.
It seems fairly straightforward, but it includes a gui change which would involve a little UI work, and a little testing :)
Anyone feel like taking this one?
Cheers, Dave.
