GAP Filters
Exif support David Neary 24 Jun 14:25
  Exif support Sven Neumann 24 Jun 17:17
   GAP Filters Joao S. O. Bueno 24 Jun 19:16
    GAP Filters Henrik Brix Andersen 24 Jun 19:20
     GAP Filters Sven Neumann 24 Jun 21:55
David Neary
2003-06-24 14:25:46 UTC (almost 22 years ago)
Exif support
Hi all,
Just to inform peopel who aren't following CVS or Bugzilla, Exif support (of a kind) has been added to HEAD.
If you have libexif installed, you can now conserve exif data stored with a jpeg across GIMP edits. There are no interface bells and whistles, no metadata editor, no exif data editor. If the data is there, it's loaded up and associated with the GimpImage, and if it's there at save time (when you're saving as jpeg), it's written out to the output file.
This is step 1 in a grand plan (which will probably never get to step 5).
1) Don't destroy exif information 2) Don't destroy tiff/ep information 3) Don't destroy IPTC/XPC information 4) Update all of the data elements directly associated with the image for which there is no extra user interraction required (width/height, comment)
5) Provide a nice way to edit metadata 6) Have metadata associated with layers rather than images, and have a nice way to merge metadata from different sources.
Anyone know of a free C library that parses tiff/ep, iptc and xmp data? How about Dublin Core?
Anyway, this is just an information email... but if people have ideas for nice external libraries to do the rest of this stuff, they're welcome.
Just to preempts the PMT (Picture Metadata Toolkit) suggestion, OpenTIFF and OpenExif are C++ - and do we really want to have Xerces/C++ as a dependency of the gimp for xmp/iptc support?
Cheers, Dave.
2003-06-24 17:17:03 UTC (almost 22 years ago)
Exif support
David Neary writes:
There's more nice stuff being added to CVS such as a grid and persistent text layers. I will try not to wait too long with the 1.3.16 release...
Joao S. O. Bueno
2003-06-24 19:16:04 UTC (almost 22 years ago)
GAP Filters
Hello ...
Where have teh GAP filters gone in the 1.3.x tree?
I've found them in the plug-ins->gap in the 1.2.x,
and I am intending to modify the "filter all layers", to do aply another filter with variable parameters based on the Value information of a mapping drawable.
Easy to do, and powerfull enough to make a lot of cool effects.
JS ->
2003-06-24 19:20:33 UTC (almost 22 years ago)
GAP Filters
GAP has been moved to the gimp-gab cvs module.
Sincerely, ./Brix
2003-06-24 21:55:42 UTC (almost 22 years ago)
GAP Filters
Henrik Brix Andersen writes:
cvs module "gimp-gap" of course
There are inofficial CVS snapshots on http://sven.gimp.org/. But please don't bug me with any problems you might have to compile or run them...
