C plugin writer wannabe(more like newbie) has questions...
C plugin writer wannabe(more like newbie) has questions... Kenny Law 10 Jun 17:56
  C plugin writer wannabe(more like newbie) has questions... Sven Neumann 10 Jun 18:55
Kenny Law
2003-06-10 17:56:50 UTC (over 22 years ago)
Hi all,
I am now moving from script-fu/perl-fu scripting and entering the world of C plugin writing for GIMP. Only reason I am doing this is because I need to get information about pixels on the drawable(quite a significant number of pixels)
I have read the good tutorial "Essentials Of a Plug-in" by Kevin Turner, and I have a few things that I just want to ask about plug-in writing in general.
a) Where do I find plug-ins with the C code instead of the executable ones in the plugin directory? I like learning by reading other source codes and could anyone tell me which one is well commented so that I get what's going on?
b) I have read the online documentation on libgimp http://gimp-plug-ins.sourceforge.net/doc/libgimp/html/
Unfortunately, I find it hard to use because not everything in there is documented, as in I have no idea what some of the functions do(although most function names are pretty well defined) and I have no idea what sort of parameters it wants me to pass in. Can anyone tell me if there is a source of help that will explain the functions in detail?
c) Basically, I just want to get information in a pixel? Thing is, if i use this function:
void gimp_pixel_rgn_get_pixel (GimpPixelRgn *pr, guchar *buf, gint x, gint y);
Only thing I don't understand is what is the datatype guchar, and how much memory do we allocate to the buf pointer? And in this buf pointer, what information is actually being returned? Basically, I just need to know what color the pixel is. Will that information be returned?
There you go..newbie with tons of questions. I hope you understood what I was trying to ask because I have 0 experience in writing gimp plugins.
Thanks all in advance!
Kenny
2003-06-10 18:55:52 UTC (over 22 years ago)
"Kenny Law" writes:
a) Where do I find plug-ins with the C code instead of the executable ones in the plugin directory? I like learning by reading other source codes.
There are more than hundred plug-ins included in the GIMP tarball. I suggest you start looking there.
This documentation, or actually a more uptodate version of it, is also included in the source tarball. Have a look at the devel-docs directory.
Unfortunately, I find it hard to use because not everything in there is documented, as in I have no idea what some of the functions do (although most function names are pretty well defined) and I have no idea what sort of parameters it wants me to pass in.
If you installed the GIMP API reference next to the GLib and GTK+ API references, you could click on most data types and get to the relevant documentation that way. Here's an online version of the GIMP-1.3 API reference which is properly cross-linked:
http://developer.gimp.org/api/1.3/
However you will need some more docs than the API reference can give you. Simon Budig wrote an excellent paper for last year's Guadec:
http://www.home.unix-ag.org/simon/gimp/guadec2002/gimp-plugin/html/
