Gimp Arrays in Perl
How do I test my perl scripts? Kenny Law 02 Jun 13:20
  How do I test my perl scripts? Marc) (A.) (Lehmann 02 Jun 17:07
   Gimp Arrays in Perl Kenny Law 02 Jun 23:19
    Gimp Arrays in Perl Shlomi Fish 03 Jun 09:54
     Gimp Arrays in Perl Marc) (A.) (Lehmann 03 Jun 15:10
Kenny Law
2003-06-02 13:20:39 UTC (almost 22 years ago)
I have a question on how to test my perl scripts.
I am now using Gimp 1.2.3 by the way.
So I wrote a script and I called it whatever.pl
I made it executable by
chmod a+x whatever.pl
Then I try to run it by entering Gimp, and starting the Perl Server by going to Xtns->Perl->Server
Nothing seems to come up at all, so I went ahead and typed ./whatever.pl
Thing is, I did not save the pl file to the usr/lib/gimp/1.2/plug-ins directory.
Is that gonna affect anything?
Can someone tell me an easy way to test my scripts without registering a script? Or do I need to register it because my script deals directly on an image?
Kenny
Marc) (A.) (Lehmann
2003-06-02 17:07:30 UTC (almost 22 years ago)
the perl server only outputs some text on the console (or whatever is connected to the stdout of your gimp process). not seeing anything is, therefore, not a bad sign ;)
that's ok.
Not that I'd know.
If you want your script to show up in the menus, yes, you need to copy it to a plug-ins directory.
If you just start it, it should open a dialog. If it is an -type plug-in it should enable you to select the image and layer to work on (but that is not heavily tested).
I assume nothing like this happens in your case?
Kenny Law
2003-06-02 23:19:11 UTC (almost 22 years ago)
Gimp Arrays in Perl
First of all, just wanna thank you guys especially Chris, Branko, Marc and Dov for answering some of my questions the past 2 days. Your help is greatly appreciated.
Anyway, my question regards the gimp_pencil tool. One of its parameters is an array of floats. I tried to pass in this by doing
//just imagine all variables contain integers #1.
@positions = (0, $startPos, $width, $startPos); gimp_pencil($layer, 4, @positions );
#2.
gimp_pencil($layer, 4, (0, $startPos, $width, $startPos) );
Everytime I try to run this script, Gimp pops me a message and says:
perl-arrayref required as datatype for a gimp array at blahdirectory then line number (ERROR)
Anyone knows how do I fix this?
Thanks all!
Kenny
Shlomi Fish
2003-06-03 09:54:25 UTC (almost 22 years ago)
Gimp Arrays in Perl
That should be:
gimp_pencil($layer, 4, \@positions);
#2.
That should be:
gimp_pencil($layer, 4, [0, $startPos, $width, $startPos]);
You need to pass a reference to an array. In both cases you passed the array itself as multiple arguments to the functions. For more information consult "perldoc perlref".
Shlomi Fish
---------------------------------------------------------------------- Shlomi Fish shlomif@vipe.technion.ac.il Home Page: http://t2.technion.ac.il/~shlomif/
An apple a day will keep a doctor away. Two apples a day will keep two doctors away.
Falk Fish
Marc) (A.) (Lehmann
2003-06-03 15:10:07 UTC (almost 22 years ago)
Gimp Arrays in Perl
To add, arrays are always passed _into_ the gimp as references [...]. Functions returning a single array return a list, e.g.
my @images = Gimp->list_images; # or so, foggy
And functions returning an array and something else return an arrayref. There is no general rule, but if you do this:
Gimp::set_trace(-1);
(you can pass in flags like TRACE_CALL etc.. instead of -1, see perldoc Gimp), you will see what, exactly, will be passed to the pdb function. That's very handy when debugging scripts.
