1.2.4
24 of 24 messages available
1.2.4 David Neary 10 May 23:28
  1.2.4 Robert L Krawitz 10 May 23:52
  1.2.4 Sven Neumann 11 May 01:53
   1.2.4 Manish Singh 11 May 02:01
   1.2.4 David Neary 11 May 14:51
   1.2.4 David Neary 11 May 14:52
    1.2.4 Sven Neumann 11 May 15:16
     1.2.4 Marc) (A.) (Lehmann 11 May 16:10
      1.2.4 Carol Spears 11 May 18:04
       1.2.4 Marc) (A.) (Lehmann 11 May 20:53
        1.2.4 Carol Spears 12 May 04:09
      1.2.4 Sven Neumann 11 May 20:55
       1.2.4 Marc) (A.) (Lehmann 11 May 20:59
    1.2.4 Branko Collin 11 May 15:27
    1.2.4 Branko Collin 11 May 15:31
     1.2.4 David Neary 11 May 15:36
      1.2.4 David Neary 11 May 19:28
       1.2.4 Christian Rose 11 May 22:39
        1.2.4 David Neary 12 May 09:33
         1.2.4 Christian Rose 12 May 10:28
          1.2.4 David Neary 12 May 10:54
           1.2.4 Christian Rose 12 May 15:54
            1.2.4 David Neary 12 May 16:38
  1.2.4 Kevin Cozens 12 May 18:12
David Neary
2003-05-10 23:28:51 UTC (almost 22 years ago)
1.2.4
Hi all,
There are 19 bugs targetted for 1.2.4 in Mozilla...
Some of these bugs have been idle for a couple of years, other are fairly trivial looking, but have not been looked at much. Others have disputed patches, and have been suggested as WONTFIXes.
I suggest pushing all these bugs, with the exception of bug #83362, to a target other than 1.2.4 (either 1.2.5, 1.2.x or CLOSED with WONTFIX). IMHO 18 months without a bug-fix release on 1.2 is far too long. I would also like to suggest a policy of a point-release every 6 weeks or 2 months on 1.2, just to get fresh bug-fixes out to people.
Basically, I think we should have 1.2.4 within the next few days. The CVS is rock stable, we've had a decent shepherd in Sven stopping anything resembling unstable code from going in, and I think it's time for a release.
Cheers, Dave.
Robert L Krawitz
2003-05-10 23:52:12 UTC (almost 22 years ago)
1.2.4
Date: Sat, 10 May 2003 23:28:51 +0200 From: David Neary
What we've done with Gimp-print is to release pre-releases periodically, depending upon need (e. g. we're at 4.2.6-pre1 on our stable branch right now). As the changes are accumulated and tested we release a full point release when appropriate. The most recent full point release (4.2.5) was released in January, and I don't anticipate 4.2.6 coming out right away.
It actually wound up being about 5 months from 4.2.0 until 4.2.1, and over 4 months until 4.2.2.
2003-05-11 01:53:24 UTC (almost 22 years ago)
1.2.4
David Neary writes:
We should also revisit the seven bugs targetted for 1.2.x.
I agree that adding a 1.2.5 milestone makes sense.
What do you think we should do about #83362 then? (http://bugzilla.gnome.org/show_bug.cgi?id=83362)
I whole-heartedly agree and unless Yosh speaks up I volunteer to take his job of doing the 1.2.4 release although I really hate to do releases in the 1.2 tree. First because Yosh should do them and second because 'make dist' doesn't work in 1.2.
Manish Singh
2003-05-11 02:01:18 UTC (almost 22 years ago)
1.2.4
On Sun, May 11, 2003 at 01:53:24AM +0200, Sven Neumann wrote:
David Neary writes:
I agree as well, and I can handle the actual release. I don't really have near term time to go through the bugs however.
-Yosh
David Neary
2003-05-11 14:51:53 UTC (almost 22 years ago)
1.2.4
Sven Neumann wrote:
David Neary writes:
Well, obviously it's a blocker for 1.2.4 (Bugzilla says so :) - the question is how best to remove BLOCKER status from it.
For the most part the problems are small, or don't really exist any more - it's mostly copyright messages that could be removed if we so felt like it, since the code to which the copyright applies no longer exists. But there are a couple of sticky ones which need addressing - namely, SIOD, nlfilter and gif.
The way I see it, there are 3 solutions -
1) Accept that SIOD stays, and if repackagers want to distributee the GIMP as non-free, then so be it. Either copy gif code from another gpl program (say gif2png) or contact opriginal author for re-licencing, or add it as an exception. Contact nlfilter author for relicencing, or drop plug-in. If the contacts don't yielmd answers by the end of this week, we should make a decision.
For the rest of the code, either acknowledge that there is code that needs relicencing, and get onto the people who did it, or declare that all the code that was taken from bsd licenced software was fairly trivial, and re-licence under GPL. For the most part, the latter should do.
2) Continue to delay the release of a bug-fix patch for the gimp until we have a new, fully tested scheme interpreter, and we can get in contact with anyone who ever wrote code for the gimp and didn't realise that the BSD advertising clause was incompatible with the GPL (even if they're now working a humanitarian aid worker in the Peru highlands who haven't looked at a computer since they wrote a gimp plug-in as their final year project).
I think we should go for 1, send requests to relicence bits of borrowed code to GPL for the important bits, just declare ourselves compliant and relicence for the trivial bits, add SIOD as an exception to our GPL, and if we haven't gotten permission to relicence nlfilter by next Friday, drop it. If we haven't gotten permission to relicence gif, steal some gpl code. Or steal some GPL code now...
In any case, I think that we should split it into 3 bugs, nlfilter, gif and SIOD licencing, and for the rest, just declare everything GPL.
What's wrong with make dist in 1.2?
In any case, there are now 8 bugs targetted for 1.2.4
http://bugzilla.gnome.org/buglist.cgi?product=GIMP&bug_status=UNCONFIRMED&bug_status=NEW&bug_status=ASSIGNED&bug_status=NEEDINFO&bug_status=REOPENED&target_milestone=1.2.4&form_name=query
Of these 8, several have been set from 1.2.x.
Bug #98490 and bug #51164 are up for grabs - very shallow bugs. Who wants to fix them?
It would be nice if someone with HPUX could check if bug #15546 is still alive.
It would also be nice if someone could check that bug #82465 is still reproducible.
Bug #108004 Needs attention before 1.2.4 - once there has been some analysis done, we can see whether it's feasible to have a quick fix, or whether it gets batted back to 1.2.5.
If we want a 1.2.4 release this week, these need to be addressed.
Cheers, Dave.
David Neary
2003-05-11 14:52:35 UTC (almost 22 years ago)
1.2.4
Sven Neumann wrote:
David Neary writes:
Cheers, Dave.
2003-05-11 15:16:17 UTC (almost 22 years ago)
1.2.4
David Neary writes:
Could you try to contact the authors in question?
It never worked in the plug-ins/perl directory. The way I did the prereleases was to make dist everything but gimp-perl and add gimp-perl to the tarball manually.
Branko Collin
2003-05-11 15:27:06 UTC (almost 22 years ago)
1.2.4
On 11 May 2003, at 14:52, David Neary wrote:
Sven Neumann wrote:
David Neary writes:
From an older thread:
http://bugzilla.gnome.org/buglist.cgi?product=GIMP&bug_status=UNCONFIR MED&bug_status=NEW&bug_status=ASSIGNED&bug_status=NEEDINFO&bug_status= REOPENED&target_milestone=1.2.4&form_name=query
Cheers, Dave.
Branko Collin
2003-05-11 15:31:36 UTC (almost 22 years ago)
1.2.4
Aargh! My apologies for an earlier mail, I must have accidentally hit the Send button. :-(
Sven Neumann wrote:
David Neary writes:
Did I miss a solution (you said three)?
From an older thread ("Copyrights and licenses", May 2001):
On 29 May 2001, at 14:30, Sven Neumann wrote:
Dave Neary writes:
Sven:
Everything distributed with The GIMP should be GPL, LGPL or a compatible license. Actually we assume that all plug-ins in the GIMP distribution are GPLed.
To my mind (and I may be wrong there), plug-ins are just applications which depend on the GIMP, and an interface provided by it - so they can be licenced under any old licence that you might deign to choose. In much the same way as (say) proprietary Linux applications are just applications which depend on Linux & interfaces it provides (when distributed in binary form anyway).
So if one wanted to release a plug-in as a proprietary application (God knows why you'd want to - I don't believe anyone would pay for a module to a graphics application), I don't see any GPL issues myself. Am I wrong?
You are right. I was speaking about plug-ins/scripts distributed with The GIMP. We have choosen to make libgimp LGPL to allow others to choose different licenses for their plug-ins, but we will refuse to distribute them with The GIMP.
So it would seem the policy was only to allow GPL'ed plug-ins, even if we don't have to.
Can anyone but the author declare something to be GPL'ed? How does that work?
David Neary
2003-05-11 15:36:56 UTC (almost 22 years ago)
1.2.4
You seem to have forgotten to snip a fair amount of my mail too :)
[snip solutions 1 and 2]
Ah - the third solution is to put the whole issue on the back burner, release 1.2.4 anyway, and let third parties figure out what to do. Basically, to ignore it as an issue and remove blocker status from the bug. Forgot that one :)
From an older thread ("Copyrights and licenses", May 2001): You are right. I was speaking about plug-ins/scripts distributed with The GIMP. We have choosen to make libgimp LGPL to allow others to choose different licenses for their plug-ins, but we will refuse to distribute them with The GIMP.
Which is why we should drop nlfilter if we can't relicence it with the author's permission.
If the non-GPL code is from a BSD licenced app, and is small enough not to be considered a derived work, then the inclusion of the original code has no licencing implications for the new code. At least that's my understanding of the issue.
So when I say "declare everything GPL", I mean "don't get our knickers in a twist over 20 lines of code borrowed from a BSD licenced application" - if it is really 20 or 30 lines, then the likelihood is that whatever we ship wouldn't be called a derivative work, and we're free to licence it however we want.
Cheers, Dave.
Marc) (A.) (Lehmann
2003-05-11 16:10:54 UTC (almost 22 years ago)
1.2.4
Hmm... I can guess what goes wrong - the default make dist target will actually create a standalone gimp-perl distribution.
I don't know wether I can overwrite the dist target, but if so, what would I need to do in it?
Would it suffice if the Makefile would simply copy all distribution files into the packaging directory? That should be relatively easy, as the MANIFEST lists (or should list) all files that need packaging.
So.. maybe it's easy to fix (i.e. it might be worth to fix it).
The other alternative would be to do seperate releases (i.e. rip it out).
Carol Spears
2003-05-11 18:04:33 UTC (almost 22 years ago)
1.2.4
On 2003-05-11 at 1610.54 +0200, Marc A. Lehmann typed this:
does this mean separate downloads for people who want current gimp-1.2?
David Neary
2003-05-11 19:28:25 UTC (almost 22 years ago)
1.2.4
[snip...] for the rest, just declare everything GPL.
In addition, since the GPL itself contains an advertising clause, in so far as it obliges a certain header in GPL protected source files, I don't see how it can consider this reason for an incompatibility with the BSD type licence. I think that we can keep most of the advertising clauses and still be fully GPL compliant, in word and in spirit.
The BSD/Artistic/Apache type licences all permit relicencing, so why not just relicence to GPL, and keep the advertising clause as originally requested?
If someone can give me a decent explanation why the advertising clause is a limitation on the liberty to modify the software, I'd like to hear it. Otherwise, none of this code will cause me to lose any sleep.
Cheers,
Dave.
Marc) (A.) (Lehmann
2003-05-11 20:53:53 UTC (almost 22 years ago)
1.2.4
Well, people who want it usually do sth. like "apt-get upgrade", so it already is a seperate download ;) People who download the source would need two downloads them, of course (or use CPAN).
It has proven to be very difficult to integrate some plug-ins, especially the perl plug-in, since it's not only difficult to integrate it with automake, but plain impossible, since people expect gimp-perl to work with the vendor-supplied perl as well as with gimp, which often is plain impossible.
That's not a problem on linux and freebsd, and I assumed that admins of such broken osses like irix (I am one) would know about these issues, but this seemed to have been a wrong assumption.
Seperating gimp-perl from gimp would help pinpoint problems. If gimp works but gimp-pelr fails to link, this narrows down the area wheer one has to look.
Also, since gimp-perl is now part of every normal distribution the pressure to distribute it with gimp is not as big.
Wether it makes _sense_ to do that in the maintainance branch is a totally different question.
2003-05-11 20:55:26 UTC (almost 22 years ago)
1.2.4
writes:
exactly
I don't think it is worth fixing it now. Perhaps after the 1.2.4 release.
That's what we do for 1.3 but I don't think we should change the 1.2 distribution in such a dramatic way.
Marc) (A.) (Lehmann
2003-05-11 20:59:43 UTC (almost 22 years ago)
1.2.4
Suits me.. :/
If you could, it would be extreemly great if somebody could poke me after 1.2.4, because I'll be bound ot forget it unless pushed.
Christian Rose
2003-05-11 22:39:14 UTC (almost 22 years ago)
1.2.4
sön 2003-05-11 klockan 19.28 skrev David Neary:
The crucial difference is probably that the original BSD license, to my understanding, requires advertising not only in source files, but in all sorts of packaging, both digital and physical. A distributor is required to print the stuff on the box, etc.
I think that we can
It is an additional restriction and thus clearly deemed incompatible with the GPL (http://www.gnu.org/licenses/gpl-faq.html#OrigBSD). Additional restrictions are not allowed.
It's still free software. It's just not compatible with the GPL.
Christian
Carol Spears
2003-05-12 04:09:45 UTC (almost 22 years ago)
1.2.4
On 2003-05-11 at 2053.53 +0200, Marc A. Lehmann typed this:
please don't do this in the 1.2 branch. i would love to strip the extra stuff from gimp and offer them in a more educational environment (if you need it) but it would be bad to suddenly revert to this old way of getting gimp-perl at what might be the very last release. a mess for the web site also. this would be a web maintenance concern
it would be nice also, if someone would get perl working in the new branch. this is more like one users pipedream, however.
David Neary
2003-05-12 09:33:34 UTC (almost 22 years ago)
1.2.4
I think that we can
To be quite honest, I think this is GNU throwing a hissy fit because BSD people don't agree with them. I believe that any challenge to the licencing of code as GPL because it contains BSD code would fail.
I find it ridiculous that it's OK with the BSD/Apache/Artistic licence people that anyone can use their code for whatever they want, including relicencing the code, but the GPL (or rather GNU) people refuse to accept the code.
The GPL, in spirit, is very clear - GPL licenced code which is modified must be released under the GPL. Great. The BSD type licences are very clear too - do whatever you want, just say where the code came from in a comment. Great. Now, why not include BSD code, do whatever we want with it (basically, relicence it as GPL code), and leave the comment in?
I don't see a problem with it. And, to be honest, anyone who considers adding a comment to the top of a source file a restriction is being seriously pedantic.
Cheers, Dave.
Christian Rose
2003-05-12 10:28:46 UTC (almost 22 years ago)
1.2.4
mån 2003-05-12 klockan 09.33 skrev David Neary:
I doubt that, as the revised BSD license without the advertizing clause has been deemed perfectly compatible with the GPL (http://www.gnu.org/licenses/license-list.html#GPLCompatibleLicenses). Clearly, it's the advertising clause that causes problems.
That's the nature of the GPL. It takes measures to enforce some sort of "guaranteed" level of freedom, regardless if you like that or not. As such, it explicitly prohibits the use of any additional restrictions, however they may look like. And as such, any license that imposes additional restrictions, however free that license may otherwise be, is incompatible with the GPL.
Because the GPL does not allow additional restrictions. If you add additional restrictions, the license conditions are void and the software is not GPL licensed anymore -- and may not even be redistributable at all, as it is the license that permits redistribution.
I thought I had already mentioned that this isn't only about source file comments (http://www.gnu.org/philosophy/bsd.html)... To be honest, if you have problems with the original BSD license and GPL incompatibility, I suggest you bring it up on a GNU mailing list. Or any other list with legal experts. This discussion has little to do with GIMP. You're free to cc: me directly on such a discussion, but I don't think the GIMP mailing list is the right forum.
Christian
David Neary
2003-05-12 10:54:08 UTC (almost 22 years ago)
1.2.4
Ah. That clears things up. Almost all of the questionable code (including the gif code, and the nlfilt code) is not BSD licenced in the old sense, only in the new sense. It does not require a notice on all materials, and resembles more the X11 licence, or the artistic licence V. 2.0 - in which case, it seems to me like we can steamroller through this problem, and do as I suggested (GPL all the files in question, leaving in the comment from the original author).
Or am I missing something?
As I said above, the code in question doesn't have the 'obnoxious advertising clause' in it. Does this mean that we can relicence it, and stay GPL compliant? As you suggest, I'm going to cc a GNU person here.
Unfortunately, since we're talking about the licencing of code distributed with the GIMP, this is still an appropriate forum. Changing the subject name, though.
Cheers, Dave.
Christian Rose
2003-05-12 15:54:22 UTC (almost 22 years ago)
1.2.4
mån 2003-05-12 klockan 10.54 skrev David Neary:
I'm not sure I understand what you're trying to do and what you're trying to accomplish.
For files with BSD license but without the advertizing clause, there is no problem as I see it, and there's no need to change the license. It's already compatible with the GPL and the aggregate is distributable, AFAIK. It's only those files who have BSD licenses with advertizing clauses that needs change, either by the author agreeing to change to the revised BSD license, or any other GPL compatible license.
But a change in license requires the copyright owner's permission, as one of the fundamentals of copyright is that the copyright owner solely determines the conditions (the license). Thus, it seems like overkill to ask, and get permission from, the authors (copyright owners) of all non-GPL files for relicensing to GPL when it may not be needed in all cases.
You cannot relicense without the author's permission, and I fail to see the need for that anyway if there's no advertizing clause. See above.
The discussion turned unnecessarily broad in scope and was only loosely connected to the GIMP problem. If you intend to keep it connected to the GIMP problem, I fully agree that keeping it on this list is the best thing to do.
Christian
David Neary
2003-05-12 16:38:05 UTC (almost 22 years ago)
1.2.4
It's entirely possible that I am misunderstanding the issue.
As I understand it, there are two separate issue - licencing and copyright. Copyright of the code in question will, of course, rest with the original author.
Licencing, on the other hand, consists of a series of conditions which govern the distribution of the product. In the case of the gimp, the licence (if it can be called that) on the code in question is of the type
/* Copyright Joe Bloggs 1947 *
* You are free to do whatever you want with this, just keep this * comment in future versions to let people know I was the * original author.
I understood this to be what people refer to as a BSD type licence (it obviously is not the BSD licence). The questionable code is this code.
My understanding of the GPL is that if you include code in a GPL application, you must release that code under the GPL. And there is the issue.
I disagree with you here, as much code under modified BSD licences, or in the public domain, has been licenced under licences other than their original licence without the author's permission (see, as an example, the TCP stack in Windows NT). In fact, the artistic/BSD/X11/Apache type licences have no problem with people using their code under a different licence.
GPL licenced code requires relicencing of derivative works under the same licence, but most free software licences do not have this requirement.
I believe that the GPL requires us to relicence this code to the GPL, or stop distributing it. I believe that we can relicence it without the consent of the original authors, because the licence with which the code was distributed permits it. As I understand it, what GNU calls a "GPL compatible licence" is "a licence which permits derived works to be GPL licenced".
My fault :) Imprecision in the type of discussion where precise language is required.aHopefully this mail will clear things up.
Cheers, Dave.
Kevin Cozens
2003-05-12 18:12:26 UTC (almost 22 years ago)
1.2.4
Did you mean to say Bugzilla? Mozilla is the name of a web browser.
Cheers!
Kevin. (http://www.interlog.com/~kcozens/)
Owner of Elecraft K2 #2172 |"What are we going to do today, Borg?" E-mail:kcozens at interlog dot com|"Same thing we always do, Pinkutus: Packet:ve3syb@ve3yra.#con.on.ca.na| Try to assimilate the world!" #include | -Pinkutus & the Borg
